Results 1 to 4 of 4
Thread: 1jz fuel system components
    Cressyskidder Grease Monkey Bowlsclubboy's Avatar
    Albury NSW
    Default 1jz fuel system components
    Hey guys, just about to do a big order for my fuel system from summit and need some help.
    I was planning on the following for my fuel system, i'm hoping it would be enough for around 500rwhp and be fairly easily upgraded for more if i go to a 2j bottom end one day.
    AN-8 hose from fuel cell - 40 micron filter - carter performance lift pump - surge tank - AN-6 hose to 10 micron filter - AN-6 hose to bosch 044 - AN-6 hose to fuel rail (650cc sard) - AN-6 hose to aeromotive compact FPR - AN-6 hose return line.
    I know the pumps are up to it for one thing.
    I was planning on using An-8 feed and An-6 return but the only easily available banjo fittings to fit the fuel rail feed and return are AN-6. I assumed that it wouldnt be a problem having the same size hoses but i had better ask before i start ordering.
    I've been using an AN-8 feed and standard feed hose as the return line for years now but i want to pretty everything up.
    Cheers guys.
    1992 MX83 Cressida Grande-1JZ-GTE...Actively Dori.
    Albury NSW
    Default Re: 1jz fuel system components
    Perhaps I need to rephrase my newbish question (or lack of an actual question)
    Will there be any detrimental effects to the performance of my fuel system if I run a feed and return line of the same size?
    I can always install another 044 and -6 feed line if I run out of fuel one day.
    I'm running the same size feed and return (pretty sure they're -6) on my 2JZ. 442rwhp and all works good. I have dual feed though which I think is a wise idea for high power levels.
    Albury NSW
    Cheers Norbie! Looks like summit will get another $1000 of my hard earned seeing as the dollar is strong atm
  1. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 06:56 AM
  2. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  3. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
  4. EFI fuel system
    Last Post: 15-12-2005, 04:39 PM
  5. Replies: 1
