Results 1 to 10 of 10
Thread: 4 stud to 5 stud, the custom way?
    Jan 2009
    Talking 4 stud to 5 stud, the custom way?
    So I have a 5spd 1uz MX73 Cressida. It's 4 stud. I like Lenso D1Rs. I want to put some on. They are 5 stud. Any dudes in QLD who can assist me with this?
    I asked a guy on the cressida forums that did it on his. Had some fat ass work equips on it. like +10s.
    He told me, the got his hubs, took out the studs, plugged and tigged the holes. Drilled out 5 new ones, machined, new studs. tada.
    Now. What will the structural integrity be like? Especially with the torque of the 1uz.
    I already have 300ZX tt 4 piston calipers, which are a straight bolt-on upgrade, so changing hubs/steerings arms etc. is a road I don't want to go down.
    Default Re: 4 stud to 5 stud, the custom way?
    Buy MS123 rear stubs
    Buy MS65 front hubs
    Fit
    Win.
    Quote Originally Posted by CrUZida View Post
    Buy MS65 front hubs
    Fit
    Win.
    Quote for truth.
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2008
    is it really that easy? i've been toying with the idea of 5 stud conversion since the monent i rang and ordered the 2j for my mx73 a year ago
    ps (stupid question) what are ms123 & ms65? is that crown? sorry i was a born and bred holden boy untill i discovered the strength of the mighty tojo
    Yes they are both Crowns, MS65 is '71-74 & MS123 is '83-87. All I can say is good luck
    Nov 2008
    good luck? does that mean they are rare? bit like the gx81 booster i try'd to find for my conversion and everyone at the wreckers laughed at me (ended up finding a booster and master from a rolla that fit in good nick for 40 bucks)
    darby / Pyr0s,
    I'd suggest a search for converting MA61 supra to 5 stud, the process is identical for MX73
    There is heaps of info out there.
    That said, I wouldn't bother (again, I've done it twice so far). I'd put the money saved in not converting to 5 stud towards 4 stud wheels...
    Wilbo's JZA80
    Wilbo's JZZ12
    Jan 2009
    but D1Rs are so nice... and only 5 studs =[
    Going rate for MS65 hubs is around $250-$350, and MS123 about $150-$200.
    Labour wise the MS65's bolt on no issues, but the rears are much easier to get someone with a press to install them. Probably $100 labour and maybe an extra $50 in parts (not including new bearings).
    The ONLY benefit is rim selection.
    If you can find decent rims in 4 stud, go that way.
    If you haven't got rims and you haven't got the hubs, then search for the rims that you want.
    If they are 5 stud, convert. If they are 4 stud leave it.
    I did it this way, and found an almost perfect set of rims in 5stud, so a conversion was needed.
    also check out takai's ma61 members rides thread hes bolted in MX83 cressida LCA struts and hubs for his 5 stud conversion on a MA61 (same as MX73).
    its more work and it increases the distance between the hubs meaning you have to run higher offset wheels on the front.
  1. Hypereutectic Pistons
    By Celica_73 in forum Tech and Conversions
    Last Post: 28-04-2008, 09:45 PM
  2. Custom 5 stud conversion hubs, 5x114.3PCD
    By 9000rpm in forum Tech and Conversions
    Last Post: 25-09-2007, 02:27 PM
