Results 16 to 30 of 31
Thread: 1jzgte wont rev past 3.5g??
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default Re: 1jzgte wont rev past 3.5g??
    Have you wired the NSW properly. If not it will run exactly how yours is running.
    1994 GZX90 Mark II 1GZ-FE V12
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    NSW? i know their a pain down south but i didnt think they affected our engines!
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    no backyard Domestic Engineer japlish's Avatar
    bk_ : it's sluggish the whole way to 4g and doesnt pick up after.
    triptek: i've heard thats possible but how? and i didn't do the wiring so that makes it even more fun
    at least all the loom/ecu is still hanging in the passenger side footwell.
    i have noticed he's used 2 pins on a 4-pin relay for something, maybe thats got something to do with the nsw?
    Destroyer of 'Drop Forged' spanners
    BK Grease Monkey bk_'s Avatar
    Quote Originally Posted by japlish View Post
    ecu was checked by an auto elec and no codes came up
    ^^ Hmm... I think that's not possible. Whether there is a problem or not, there should be atleast one code. code 55 is the good one.
    Er... maybe I'm confusing it with nissan. it's been a long while since I last pulled the codes from a toyota ecu.
    Not trying to be a Carport Converter
    Jan 2009
    senn: kickdown cable? it's manual??
    My bad, my eyes are painted on. It might have a different name, but that was what this bloke called it. When he had put the engine back together, he had accidently put the cables the wrong way around (throttle cable + kickdown cable). think he said it made the car feel sluggish and unresponsive, but yeah, it was an auto, so not applicable in this situation
    EDIT: Ah i see auto ECU, with manual box. Perhaps part of the issue is that
    http://www.toymods.net/forums/showth...699#post870699
    It's explained there on how to fix it. Post 38.
    Jul 2008
    Have you checked your fuel pressure, it sounds like it could be running out of fuel.you need to put a guage in line and see if the pressure is correct at idle and then increases with boost pressure and does not drop as the fuel requirement increases.
    Cheers, Al.
    triptek: i hate wiring, wana draw me a diagram on how to hook up the relay?
    Jan 2009
    Stolen from an american dodge forum, this is for a bosch relay (the most common i've seen):
    Link to original http://www.lxforums.com/board/showthread.php?t=98071
    Connect 85 to a Postive 12V (low amperage is fine, only used to activate the coil.)
    Connect 86 to your switched ground input (this is the ground you will use to activate the circuit)
    Connect 30 to your INPUT to the relay, or in most cases this will be the 12V that you will be SWITCHING to your load or output... Again, not 100% sure on your application, but I am going to assume this is going to be a high amperage 12V which once activated will be supplied to the fuel pump... Or if you were using ground switching on the fuel pump then this would be where you would connect the ground...
    OK, sorry that is confusing, , here, on pin 30 is what you will connect whatever line will eventually be ran across the relay and to your load.
    87a often is not connected, but if you were to use it, this would be the output line when the relay is NOT energized.
    And lastly, pin87 is your output, which will be active, effectively connecting pin 30 and 87 together when the relay is activated or energized when you complete the 12V and ground circuit on pins 85 and 86...
    relay pin diagram
    and Quoting Triptek from his link: Now connect the STA wire in the jzx90 loom to the ign/trigger pin on a relay (can't remember what the exact pin number is). Then hook the ground on the relay to the body. Your best off running a wire from the battery for the power in on the relay. Then connect the power out to the starter motor wire.
    So (i haven't done this for a couple years, correct me if i fudge it) battery connects to pin 30, pin 87 would go to the starter motor wire (30input thru a switch in the relay, to 87 out, which will only activate if there is a completed circuit on pins 85 + 86) Pin 85 would be the STA wire off the jzx90 loom, and i spose pin 86 would just be a ground to body? Pin 87A isn't used. Did i get it right triptek?
    It's been a while since i've wired up a relay, just wanted to see if i still know what i'm on about...and saving triptek having to write it out
    thanks for that senn, but it looks like i figured it out by mere chance
    big thanks goes to triptek, you saved me alot $ and !!!!!!!
    case closed
    Jan 2009
    So it's running properly now?
    Good to hear you got it running.
    yup it's running really well i'm suprised
    and it didn't cost me anything to fix which is always a bonus
    Dec 2009
    what was it?
    the nsw was wired incorrectly or as i understand not at all.
  1. JZA70 1JZGTE Engine manual ? Anyone
    By 1200det in forum Tech and Conversions
    Last Post: 12-08-2006, 09:57 AM
