Results 1 to 4 of 4
Thread: Best way to clean out second hand turbo?
    Nov 2009
    W.A
    Default Best way to clean out second hand turbo?
    Gday people
    Just picked up a second hand T25 for next to nothing. Has bugger all shaft play and seems in good nick but is a bit dirty inside from sitting in my mates workshop for the last year or so.
    Whats the best way to clean it out without damaging it?
    Is there any recommendation on solvents or sprays like throttle body cleaner that I should use? Will this bugger any internals (seals, ect).
    Cheers.
    Current Rides:
    -1988 GZ20 1ggte, undergoing head rebuild and single turbo conversion.
    -Fully sick Hyundia Getz (work car).
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Default Re: Best way to clean out second hand turbo?
    There are products around like this one, http://www.innotecworld.com/c-1064-turbo-clean-set.aspx , which allow cleaning without dismantling. Try your local performance shop.
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    Inside where? The housing or the core where the oil etc live? If it is the housings then just remove them and clean wheels and housings with petrol and a fine bristle paint brush, if it is in the core then i would get it professionally looked at.
    My 2c
    A method used to clean the compressor blades of aircraft jet engines, was to spray with WD40, let it soak for half an hour, then hose off.
    cheers Chuck.
    MS51Crown Coupe,
  1. blowing smoke on boost, 1ggte, clean motor!
    Last Post: 05-05-2006, 03:58 PM
