Results 1 to 8 of 8
Thread: kink in fuel line on mx83
    Jan 2009
    sa
    Default kink in fuel line on mx83
    i spent today putting a walbro pump in my cressida
    i noticed that the main fuel line has been bent, i dont think i could have done it as it is bent in the opposite way to what i could have, and it had plenty of movement from the rubber pipe connecting it to the tank. i guess it happened when the conversion was done.
    is it worth the hassle to fix it?
    heres some pics
    Oct 2008
    TAS
    Default Re: kink in fuel line on mx83
    i would, looks like its kinked a bit, could undo all you work fitting the pump by creating a restriction.
    only my opinion tho
    cheers,
    Will
    1983 Toyota Celica Supra
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Definitely fix it it needs full pipe volume for maximum flow.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    replace. I doubt youer gonna un kink it. usaly when its past 90deg the pipe its fudged
    Jan 2009
    sa
    its going to be hard to fix as its onpiece from the fuel pump assembly.
    can i cut it and use fuel line? or does it have to be metal?
    Nov 2007
    Yep you can cut it and use a fuel line, just make sure to clamp it on good.
    Be sure to remove any shavings or loose bits of metal after cutting so they don't remain in the pipe.
    Jan 2009
    sa
    ended up cutting it with a pipe cutter and putting two clamps on either end of the hose.
    no leaks so far lol
    Apr 2009
    Thats all I would have done as well....nice.
  1. 2TG fuel line problem!
    By Stock_22 in forum Tech and Conversions
    Last Post: 30-10-2007, 06:13 PM
  2. TA22 Fuel Line questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 22-08-2006, 04:32 PM
  3. Spoonter fuel line
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 30-03-2006, 07:32 PM
  4. Replies: 1
