The only cheap replacements are those you would rip off wrecks. However, these carbs would be of similar age and no guarantee they'd be any better than what you have.
You can still get carb rebuild kits, but you need to make sure you specify the right carby as there were a couple of different versions.
Rebuilding the carby is not difficult and with some patience and being careful where things go, you should be able to pull down and rebuild the carb in a day (a day 'cos tis is your first time). Matter of fact.. make it a weekend. Put the disassembled parts in cleaner and make them nice and clean and no debri sticking to any parts.
You just can't use any carby. Some carbys like some webber ones, will fit, but you need to make sure the throttle and any other connections (fuels lines etc) match up, and even then you may need to tune the engine etc for the new carby. And, new carbies... or fully reconditioned ones are not cheap. Thye aren't that expensive, but I get the feeling you are looking to get out of this cheaply - and buying a new or recond carby will dent your wallet a little bit.
Check your air filter and make sure it is clean. get some compressed air and blow it clean if it is dirty. If really dirty and not coming clean then you may need to fork out some cash and get a new cleaner element.
Check your spark plugs to make sure they are within specs and clean.
Check the points and make sure they are set to specification. If the contacts on the points are burnt then buy a set of new points.
Your carby could need the mixture adjusted, but I would assume the mechanics would of checked that. Some carbs hav e the micture blocked so it can't be adjusted - and am not sure if that's the case with yours.
Also look down the carby to make sure the choke is coming off properly when the engine is at normal temperature. If the choke butterfly is sticking it will make the engine run rich.
Hope that helps.
seeyuzz
river
