Results 16 to 30 of 33
Thread: how to manual shift a340 for under $10
    Nov 2007
    Default Re: how to manual shift a340 for under $10
    Well most MK3 Supras, z30 soarers had the paddle for the cruise control so no need to put another wheel on.
    Junior Member Domestic Engineer Hurricane's Avatar
    nice info, im goin to have to try this out
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    subscribed cos i can never find this thread when i need it
    Never late in an x8
    confirmend that this will work on jza80 with TPS controlled line pressure, when the power is disconnected from gearbox it runs full line pressure, and you can just wire up the same as this thread
    Jan 2009
    Malaysia
    Hi All,
    I'm running A340e from aristo & plan to manual shift with Haltech PS2000 for engine. With the above diagram can we get full line presure?.
    If yes, I plan to control the presure reduction solenoid via haltech with PWM output.
    wa
    Sorry for the thread dig but I need to sort this out for my trans in my jzx100.
    I currently have what I have been told is a spragless mv autos a340 out of a jzx90.
    I need to shift the box without the factory ecu because the loom is no longer in the car, I am running a ps2000 and need something for the auto, I'm also running a hurst promatic shifter and mv brackets
    Nov 2011
    u just need power to sol a when in low
    power to sol a and b when in second
    and power to sol b when in drive
    then turn power off to get overdrive
    can be done for under 2 bucks if your tight as I try to use relays to do the triggering which costs abit more
    u need to use the Toyota inhibitor wiring and 2 diodes
    lock converter will not work and the line pressure will not work if your box has one
    without the trans harness makes it abit harder as u have nothing to go by
    I normally ask for the shift solenoid connector and the inhibitor connecter when I make these for people
    wa
    I have the connectors and a little pigtail of wiring but that's all
    If I hook all these from the neutral start switch it should be fine?
    Is there any advantages to using a relay to do the triggering as opposed to not using one.
    I have an mv shift box should I just use that? Only thing is I have heard of heaps of problems with these.
    The box has a kick down cable so it is a three solenoid box.
    Nov 2011
    the mv boxes get feedback when they are used in cars that have gear position indicators in the dash
    if u have it maybe use it
    but its so easy to make one I never need to buy the mv box that's couple hundred bucks
    just find what the wires do that u have and hook them up without relays as its easier to understand
    if u havnt made one before
    the 3rd solenoid is the lockup converter so leave that off or u could hook it up to a switch
    but u need to remember to turn it off most of the time so I just leave it off because most customers
    will probably forget to turn it off and then burn out the converter
    Aug 2017
    New South Wales
    Sorry to dig but anyone have the pictures that no longer work?
    Oct 2017
    Quote Originally Posted by jchantrey View Post
    This may help
    https://imgur.com/a/SQlPG
    Sep 2017
    Nsw
    Quote Originally Posted by dumbass View Post
    Dumbass I have a early 1uz and a340 (93 I believe) to go in my 1975 hilux.
    Would you be interested in making one of these up for me? I want it full manual with lockup. I’ll be using a b&m ratchet shifter with mv brackets. Is this possible?
    Sep 2017
    Nsw
    Also, does this cause the shifts to be ultra firm all the time like a manual valve body?
    Nov 2011
    ive got a tip tronic kit for the old a340 boxes if u want to buy one of them
    manual shifting of these boxes wont firm up the shifts it will just make them a tiny bit faster
    u need to mod the springs in the valve body to get firmer shifts
    Sep 2017
    Nsw
    Ahh ok mate cheers. I’ll go the mv full manual valve body.
    Thanks
  1. A340 Shift Controller issues
    By rob_o in forum Tech and Conversions
    Last Post: 12-12-2008, 05:21 PM
  2. Replies: 5
    Last Post: 29-01-2008, 07:35 AM
  3. GUIDE: Changing your Gearbox Shift Solenoids (Cressida MX83)
    By johnnilicte in forum Tech and Conversions
    Last Post: 05-11-2007, 05:42 PM
  4. A340 - manualised?
    By SL666 in forum Tech and Conversions
    Last Post: 01-03-2006, 01:34 PM
