Results 1 to 13 of 13
Thread: cressida plus clutch
    Apr 2008
    Default cressida plus clutch
    Hi all, i have recently fitted a W58 to my MX83 cressida. All is fine with the swap, but I am getting the OD on/off light on the dash constantly flashing at me. Does anyone out there know how to stop this, a resistor perhaps?
    Also my cruise isnt working (dunno if it was before the swap), is this tied into the auto?
    cue
    Default Re: cressida plus clutch
    Disconnect the O/D light LOL.
    With your cruise, make sure the cruise control ecu doesn't think your in Neutral.
    If the Cressida runs a separate ECT ECU then unplugging that will stop the O/D light from flashing. (the MX73 and the MA70 do, just not sure about the MX83).
    Failing that, removing the globe is the only way to get it to stop flashing.
    With the cruise, disconnect the THICK B-W wire going into the cruise box. It will fix it (assuming it was working beforehand)
    Is it possible to use cruise with a manual?
    yes.
    Should have a clutch switch wired into the neutral terminal on the cruise ecu though.
    I was going to wire one up on the Supra Rudi, I just couldn't be bothered in the end
    Plus, if you change gears quick enough the cruise doesn't care.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Quote Originally Posted by CrUZida View Post
    ECT is in the Engine ECU in MX83. I'd just remove the globe.
    Sorry if that came across as a dig, it wasn't one. (PS I haven't wired it in yet either LOL...one day haha)
    I still granny shift and don't double declutch like im supposed to ROFLMAO.
    Apr 2008
    awesome thanks everyone, ill have a go on the weekend and sort it out
    no backyard Domestic Engineer japlish's Avatar
    on a side note the ''r'' on my dash lights up when you select reverse (r154) the guy i bought it off did it, thought it was a neat touch
    The 'R' is connected to the reverse lights, so if the reverse lights are hooked up (as they should be), the R works.
    Apr 2008
    thats cool!
    can anyone tell me which plug that goes to the auto is the reverse lights plug?
    The one that goes to where the shifter connects to.
    PRND21 and the NSW are all on the same plug.
  1. Clutch for R154
    By millers in forum Tech and Conversions
    Last Post: 21-11-2008, 02:30 PM
  2. aw11 clutch problems
    By KARNAGE in forum Tech and Conversions
    Last Post: 31-10-2008, 01:54 PM
  3. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 09:12 AM
