Results 16 to 18 of 18
Thread: 2JZGE JZA80 auto info
    Perth WA
    Default Re: 2JZGE JZA80 auto info
    I know the early model NA JZA80's are such. The wiring for the auto transmission is found within the engine loom, that feeds both the ECU, and the engine plugs too - the neutral start switch is also contained in the wiring going to the auto.
    Quote Originally Posted by levinte27 View Post
    Thanks for the info.
    Is a JZA80 auto a 3 wire plug and cable controlled line pressure, as I have found one of these.
    Also where as the wires going to solenoids. Is this from the auto shifter if so I with have to intergrate this into my column shift somehow.
    What neutral safety switch will I need to get as the cae is a manual atm.
    Philip
    take a picture of the box and upload it
    Jul 2009
    Just to add a bit to this, you will have to watch out for part compatibility. I've been looking (not measured yet) at an early celsior box as well as an 88 supra turbo box.
    The ring gears aren't interchangeable because of the engine output bolt patterns. Torque convertors can't be swapped between ring gears because of a slight difference in the PCD of the bolts. Bell housings are a different length so its not just a simple swap of bell/ring gear/convertor, as the input shaft spacing is different. I've put the celsior convertor on the supra box and it appears to spin freely (without the bell on), but the supra convertor on the celsior box (with bell) has a slight fouling on something, which means the convertor cross section or gearbox input shaft length is slightly different.
    Just some FYI.
  1. auto not shifting 1ggte/a340e no auto computer
    Last Post: 28-11-2009, 08:38 PM
  2. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 06:15 PM
