Results 1 to 15 of 24
Thread: how to get more out of a 1GGTE
    Nov 2008
    Red face how to get more out of a 1GGTE
    HI Guys,
    I have a 1GGTE that goes alright but i now feel like it needs more power.
    Mods:
    HKS mushroom
    Supra FMIC
    3inc exhaust
    Im after the cheapest way to get more power, i was thinking bleed valve and a bigger FMIC.
    I need to know about injectors and turbos, what fits and other models i can take parts from, i.e GTR injectors for a CA18.
    Any help would be great and also peoples experience with what has worked and not worked.
    Thanks for your help in advance.
    Kieran
    Default Re: how to get more out of a 1GGTE
    $20 turbosmart bleed valve will enable you to get some more boost.
    But make sure your intercooler is up to keeping it cold. (ie, get that bigger FMIC).
    What car is it in? GZ20 I'm guessing?
    If so, the next best upgrade is a new (bigger) engine.
    Quote Originally Posted by sone3 View Post
    HI Guys,
    Mods:
    HKS mushroom
    Supra FMIC
    3inc exhaust
    Kieran
    Hi mate.. i used to have a gz10 with a 1ggte..
    mods were..3" exhaust, FMIC with 2.5-3" piping, K&N filter..turbosmart bleed valve..
    also had a t piece manifold made up and ran a high flowed ct26 and safc..
    on 16-17psi i made 276rwhp...
    i also had some adjustable cam gears but they werent used yet.. i was planning to run 1gge cams.. but that involves re-shimming etc..
    also, from memore 7mgte injectors fit (440cc).. but you need SAFC or something similar to control them otherwise you overfuel hardcore..
    good luck with it mate..
    Stomps
    Nov 2008
    Thanks guys,
    The car is a GX81 Cresta. Thinking im going to go with the bleeder and FMIC. Didnt really want to spend a heap on the motor as i do at some stage want to go 1JZ out of the same model (non-vvti).
    Anyone know what size intercooler i can run? i would measure it up and i will to be 100%, but if anyone has done it before it would be good to know.
    There are quite a few threads here about 1G performance and also regarding modifications to Cressida's (to suit things like intercoolers and dumps for 1JZ conversions). Best to have a look for those first.
    In regards to the size of the cooler, I would start by getting something that you wont need to replace when you get the 1JZ conversion done. The typical size is 600x300x75 and fits quite well in the front, and to save a little money, make the pipes connect to the factory ones as soon as possible to minimise the fabrication required.
    This should net you a decent amount of power and you already have the added benefit of it being manual. Most threads indicate that 180-190rwkW is possible on the stock turbos so if you feel the need for any more then its probably best to wait for the 1JZ conversion.
    your mums an Carport Converter pato's Avatar
    more boost, justjap cooler or something similar,
    total $200-300
    i made 171rwkw with that setup
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    Nov 2008
    Cheers man, dont use the forum much so not to savy with how it works but thanks for the tip.
    Im thinking the same thing if im going to be spending 1K plus on mods for a 1g i would rather just save the extra cash and go 1j. the way the intercooler is set up at the moment to upgrade and re-mount with new pipes should be simple as, might not even need fab work.
    Thanks for the support guys this has just reaffirmed what i was thinking, so im off to get a bleed valve and FMIC this weekend.
    Thanks again
    i would just go for a standard 600x300x76 cooler and make it fit.. but im only saying that coz i played around with "bolt in" upgrade intercoolers and found them only marginally more effective than factory.. and not worth the cost...
    remember also.. they have a fuel cut.. so if you want to run more than about 12psi.. you need an FCD or some form of fuel controller..
    Stomps
    Nov 2008
    Cool,
    didnt know they had a fuel cut, so thats something good to know.
    Just have to say you have all been really helpful.
    mine ran 15psi with no fuel cut probs.
    Factory airflow meter, comp and injectors.
    hks manifold and to4e turbo.
    Stew
    yeah, mine was strange.. initially it cut at 12odd psi.. but once i changed turbos from stock ct26 to highflow ct26 it took 16psi before cutting..
    after a basic safc tune to take some fuel out i threw 21psi at it once and it didnt cut..
    Stomps
    Nov 2007
    mate i am getting rid of all my 1G stuff, so if you need any thing give me a PM
    Stuff includes, custom exhaust manifold suit t25 flange turbo, GT2871R Turbo (on EBAY now), 440cc Injectors, HKS cams, Adjustable cam gears, HD clutch & custom flywheel, pipeing c/w turbosmart blowoff valve.... and the list goes on..
    Most of its not really a cheap mod i relise.. but just incase you want to go crazy..
    I was making around 200rwkw, which was a hoot.. You will need aftermarket ECU though
    Pm me price + spec for hks cams plz.
    RA23 - Twincharged
    JZZ20 - Daily
    Nov 2007
    Hi.
    Raise the boost to about 14 PSI or so.
    Get a larger Intercooler, don't go a big 600 x 300 if you plan on keeping the CT12's for a while, get something smaller with 2.5" inlet/outlets, Adsport on here had better results with smaller inlet/outlets.
    Get a SAFC and get it tuned, makes a big difference on 1g-gte's.
    Feb 2007
    Personally I can't advise a bleed valve. I have had 4 1G's in my time and personally would deal with the 10-12psi that you get from a good exhaust and intercooler. Yes 1 bar feels a little bit better, especially on a cold night, but you will probably start getting problems. If you want to go 1J, try to do it before you destroy this engine, if you got $1000 for it that's 1/4 of your conversion done...
    Otherwise i'd go, safc, custom y-pipe, cooler, 15-18psi for some decent power... and wait for it the bearings to go...
  1. RA28 with 1GGTE, need some advice of the o so wise ones!
    By MIN728 in forum Engine & Driveline Conversions
    Last Post: 14-05-2008, 06:08 AM
  2. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 07:15 PM
  3. is now where am i, oil feed on 1ggte what am i, pipes on a 1ggte
    By love ke70 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:14 PM
