Results 1 to 5 of 5
Thread: Fuel line
    Junior Member Grease Monkey Brad-KE35's Avatar
    Default Fuel line
    Hey guys,
    In a bit of a pickle at the moment, is there any proportion of hard fuel line you must have underneath your car to pass the pits? I was going to use the hard stuff on the straighter bits and the rubber fuel hose on bendy bits? Is this okay? I don't have an engineer yet so I haven't really asked them.
    Thanks guys.
    Brad
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
    Default Re: Fuel line
    You dont want to use rubber under the car unless protected.
    Ah I get ya thanks Adam.
    Cheers bro
    I agree with Cuzbro, you want as much hard line as possible, and it shouldn't be hard to bend it anyway.
    Seeing as you're running under the car, you should be able to get from the fuel tank/pump all the way to engine bay with hard line.
    Where does the factory one run? If it's not big enough, you could always run twin factory lines. May need a little bending to fit, but you could do that by hand.
    Cheers Steve,
    The aluminium pipe is okay to bend by hand, I may need to get a pipe bender to make it look alot neater.
    Thanks for clearing that up
    Brad
  1. fuel system
    Last Post: 02-11-2007, 12:02 PM
  2. 2TG fuel line problem!
    By Stock_22 in forum Tech and Conversions
    Last Post: 30-10-2007, 06:13 PM
  3. KE 30 20v fuel delivery and return
    By vtrfirestorm in forum Tech and Conversions
    Last Post: 23-09-2006, 07:19 PM
  4. TA22 Fuel Line questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 22-08-2006, 04:32 PM
  5. Spoonter fuel line
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 30-03-2006, 07:32 PM
