Results 1 to 6 of 6
Thread: how to isolate the gearstick hole in RWD engine conversions
    Default how to isolate the gearstick hole in RWD engine conversions
    To those people who have done any RWD engine conversion where the gearstick hole has had to be moved, how have you gone about isolating the gearstick hole in the floor?
    I've done a sr20 conversion to an e30, the gearstick hole had to be moved back about an inch so none of the factory rubbers/boots fit anymore. I get shitloads of road and engine noise coming up through the gearhole. I've tried using foam to insulate the hole but its not very effective.
    So i'm just after ideas as to how i can better isolate/insulate the gear hole.
    thanks
    Tim
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    Default Re: how to isolate the gearstick hole in RWD engine conversions
    get it welded up ?
    umm, the shifter still needs to be able to come through...
    Mar 2008
    Tasmania
    i second that, 10 mins to cut a piece of plate out and another 10 to weld it up then reuse all the stock rubbers etc and itl be just like a bought one.
    Junior Member Domestic Engineer dfunkt's Avatar
    Apr 2007
    E30 bmw or E30 corolla??
    by this, do you mean that the nissan and/or the original boots don't fit over the gearstick? or just don't bolt to the chassis anymore because there are no holes around the new shifter hole?
    to fix, plate up the original hole. then drill holes around new shifter hole so that you can mount the original (if it fits) or a nissan gear boot to reduce road noise.
    Owner of the Big Red Whale
    "i cant eat this because its too spicy" "i cant eat that because it has green stuff in it" "i cant eat that because its chilli soup with Blair's Ultra Death Sauce in it"... winge winge winge...
    On the two conversions I have done, I have simply rivetted a plate over the "excess" hole, and then re-fitted the factory boots to the floor.
    Maybe you are missing one - often there are two. A small rubber one that goes on first and seals up the hole, and then a larger one that you can see popping out of your centre console.
    You can buy universal ones for the second boot, and hit up the wreckers for the first one if you don't have it.
    Now - RA23-WRX
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. GUIDE: ISCV Wiring / M-REL Wiring
    Last Post: 17-07-2011, 02:36 PM
  3. 4age 20v Silvertop - Check engine light?
    By Macross in forum Tech and Conversions
    Last Post: 29-09-2010, 08:45 AM
  4. MA70 --> JZA70 Conversion
