Results 16 to 18 of 18
Thread: auto not shifting 1ggte/a340e no auto computer
    Default Re: auto not shifting 1ggte/a340e no auto computer
    Quote Originally Posted by CrUZida View Post
    That shift pattern is what happens when it has NO control (ie, the ect ecu is unplugged, no power, something like that).
    When you have no speed wires I found that mine just hunted between gears a LOT, and was very hesistant to change into overdrive.
    SPD is the wire from the dash to the ecu (it should be already behind the glovebox, L-W from *memory*)
    SP2 is the sensor on the back of the gearbox.
    yeah, that is exactly what mine did and what adams does.. so its definitely missing a speed wire..
    awesome.. should be an easy fix.. thanks heaps guys..
    Stomps
    Nov 2007
    Like I said, from looking at Toyodiy, it seems that 3rd Gen 1g-gte's had the auto controlled by the Engine ECU, where as other gens had a separate controller.
    Thanks.
    Although mine's a 1ggze it's still most likely the same configeration as it was also from a GX81. It's a 3rd Gen from a 1988 Model.
    I had the same problem but overcame it by fitting the actual speedo from the GX81 to my car and connecting the appropriate wire from the ECU to the speedo.
    No gearbox speed sensor required and solved problem immediately
    Another bonus is that the Km's on the speedo now reflect what has been done by the Engine
    1g-gze Corona RT132 (Daily)
    RA23 Celica (Project under way)
    RT81 & MS112 (Still Thinking About It!)
    Wife thinks i'm mad (yep... she's right!)
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 07:11 PM
  2. Replies: 5
    Last Post: 29-01-2008, 08:35 AM
  3. 1jz manual conversion...auto computer?
    By chicane ma71jz in forum Tech and Conversions
    Last Post: 06-08-2006, 08:14 PM
