a drinking straw, a rubber band, and a paper clip.... wait, you aren't macgyver
ra60/sa63/ra65 steerign arms should all be the same, bar that, i unaware of anything compatible... i know ma61 is a no-go![]()
OK, ladies and gents, I'm trying to fit some SA63 struts into my Sprinter (just because they were lying around and I wanted the brakes).
Now I've messed around so the strut, spring and strut top all fit ok, then I discovered that the SA63 strut doesn't bolt to the AE86 steering arm (bolt spacing is different).
So it now seems like I need a pair of SA63 steering arms. But before heading to the wrekcers, I was just wondering what else I could look for?
Thanks
Hen
I hope the rest of your reply is more correct than that commentOriginally Posted by ViPeR_NiPPleX
Fit the lower arm from the Celica - the ball joint is a different size also. You'll still have to sort out your camber problem separately, but I presume you've got that workd out already.
yer power steer kanuckles share the same part number with rt142/st141 ronas
or any of the power steer 60 series celicas.
dan
Also note that power-steering and non-power-steering xA6x arms are the same fit but different lengths, something else to consider.
