Results 1 to 6 of 6
Thread: Pulsation Damper - Required???
    oregon
    Question Pulsation Damper - Required???
    the TVIS equipped cars came with a pulsation damper part number 23270 below.
    In the high comp engines it appears the damper went away..... when I look for 23270, it is no longer an option
    I've got a high comp(smallport) 4AGE engine, standalone, RC 320cc low ohm injectors, fuel pump is from B18 equipped Integras(115 lph), TOM'S 20V FPR(no vacuum pull off)
    So, my question is..... Do I need a pulsation damper?
    Last edited by oldeskewltoy; 21-11-2009 at 02:03 PM. Reason: answering question asked in 1st response
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: Pulsation Damper - Required???
    do u have a bigport or smallport the 100kw motors ditched tvis
    building my 4agte ae82
    oregon
    It is a smallport engine with a custom intake manifold for rwd application....
    ADDENDUN question: Can a TPS function if mounted upside down? What I'm getting at is the TPS plug, and the pulse damper are what interfere with each other, SOOOO if I can mount the TPS upside down, the plug will face forward, instead of rearward, providing enough room to mount the pulse damper....
    So, can the throttle position sensor (4AGE 1990+ and 1UZ in USA) be mounted upside down?
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    The TPS is simply either a variable resistor or a switch assembly (depending on model), if it will physically fit then it will work. Give it a try.
    wa
    Quote Originally Posted by TC1600 View Post
    correct, also turf the pulsation damper in the bin it is just to reduce noise.
    Victoria, Mt Macedon
    I ditched my pulsation dampener and noticed no difference.
    Hen
  1. Rear Damper for AE86, TA22, RA23/28/40/45 etc.
    By SeptemberSquall in forum Tech and Conversions
    Last Post: 11-03-2008, 10:58 AM
