Results 1 to 4 of 4
Thread: Identifying an R series gearbox
    Beer Fueled Domestic Engineer doobs's Avatar
    Default Identifying an R series gearbox
    Ey all,
    I have an R series gearbox, what I thought was an R154, it has been on my 7MGTE ever since I have had it.
    The input shaft is 163mm.
    From what I can gather from the forums, ALL r154s had a 190mm input shaft, although I did read that pre 96 R154s have a 160mm shaft..
    So it leaves me thinking, what gearbox do I actually have...
    Is there any other information or markings on the box that will shed some light on what it is?
    Thanx
    Default Re: Identifying an R series gearbox
    I can only say that NOT all R154's have the same input shaft. The 7M are different length to those fitted to JZ series AFAIK. A while back there was a nice picture that showed all the W series boxes side by side and how to ID them which was great. The R154 has 4 'squares' made by the ribs on the side where as the W58 etc has only 3. If still unsure you could always weigh it, as there is a considerable weight difference between the r154 and W55/7/8. Cheers
    Quote Originally Posted by hemi twofifteen turbo View Post
    Thanx for that, I know its an R series box, its well over 40kg, just not 100% sure is an R154. I know it works behind one though.
    AFAIK ALL R154's have the same size shaft, 190mm
    The early R151 has a ~160mm shaft, and I believe the late R151's have a 190mm shaft, but thats unconfirmed.
    Plenty of people have bolted early R154's to JZ motor using the stock JZ bellhousings.
    I believe R151's in RWD only format were used in some of the 2WD Diesel Hilux's - which may be what you have
  1. W series Speedo Drive (actually inside the gearbox)
    Last Post: 01-11-2008, 10:26 PM
  2. G series bell to T series motor
    By Grega in forum Tech and Conversions
    Last Post: 29-08-2006, 09:12 PM
  3. identifying ae101 gearbox
    By caibs in forum Tech and Conversions
    Last Post: 19-04-2006, 05:43 PM
