Results 1 to 4 of 4
Thread: 1ggte accelerater cable
    May 2009
    victoria
    Default 1ggte accelerater cable
    hey guys ive done some research to find the best option to change my **23 accelerater cable to fit my 1ggte conversion.i found that the toyota crown is a good option, although there are pretty hard to find.i just need some information on what people used and what is the best and suitable option.
    any help will be appreciated.
    thanks
    Default Re: 1ggte accelerater cable
    i used a 1j soarer cable
    cheers steve,
    1ggte, 11.22 @122mph
    I used the standard GA70 cable and pedal.
    The pedal just needed a hole drilled or something to mount it, and just needed some slight bending to get it in the right position. The cable just needed some holes drilled where it passes through the firewall so that you can bolt the GA70 plate in.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    May 2009
    victoria
    was as easy at it sounds? i heard that the toyota tarago van was a good option can anyone confirm this?
  1. Single setup on 1ggte thoughts
    By akmehd in forum Tech and Conversions
    Last Post: 24-10-2009, 10:49 AM
  2. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 04:58 PM
