Results 1 to 5 of 5
Thread: auto loom- manual ECU??
    Jan 2009
    Default auto loom- manual ECU??
    hey all probably silly question but i know sweet FA about wiring..
    just wondering if i can run an auto JZX90 loom and some sort of manual ECU in my MX83?
    any help greatly appreciated
    '83 KetO CS - locker, MA61's n manual..daily doribus
    MX83R - coils, 'zorst, nardi..jzx90 1jz conversion soon enough
    binge toymoder Grease Monkey
    vic
    Default Re: auto loom- manual ECU??
    id like to know the same thing? also do i need the manual ecu if i convert to manual or can i just use the auto one?
    ke70 20v drifta 18psi = 230rwkw
    jzx83 cressida, 14psi = TBA
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    auto will work fine just need to connect two wires to trick the ecu into thinking its in park or nuetral so it will start.
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    yeah you have to bridge out the inhibitor switch for it to work.
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    I just used an auto loom / manual ecu for a conversion with a 5sfe engine. Aside from the neutral start switch I also discovered to my dismay that the pin locations for about 20 of the wires were different between auto and manual ecus even though the connector physically fits in fine (no idea why). Be wary of this and be prepared to rewire the big connectors at the end of the loom. Its not a difficult job, just a bit fiddly in places.
  1. 2jzgte auto ecu ok with manual box?
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 19-07-2009, 02:18 PM
  2. Auto 4AGE Loom, Manual 4AGE, PROBLEM!
    By prizedbnx in forum Tech and Conversions
    Last Post: 18-04-2008, 04:03 PM
