Sounds like its Running way to Rich, the excessive Black smoke being the indicator ....
Check for codes on the computer ...
Maybe Check the Vacuum hose to the MAP sensor, but if it was off it would run pretty bad even before 2000 as well, certainly worth a look though ..
Do a visual check on the oxy sensor & wires as well, but the codes would show that up though ..
Also Pull off the Vacuum hose to the fuel pressure regulator & make sure that you haven't got any fuel in the hose which will indicate a damaged diaphram ..
There is plenty more that could cause it, but at least its a start ...
