Results 1 to 15 of 22
Thread: 4agze temperature issues
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Default 4agze temperature issues
    The missus told me today that while stuck in traffic her temp. gauge was sitting about 5mm below 'H'. Understandably it was a stinker today, but I was wanting to know what is the best way to bring down temps on such hot days?
    The car is a 4agze with SC14 with no ABV so it does heat up fairly quickly, and there is no bonnet scoop on the car. I did a coolant change not long ago with Nulon concentrate and kept whatever thermostat was in there.
    I would like to put some sort of 'measures' in place before we hit summer - would a wiring in a 2nd fan work has anyone done it? Are there thermostat's that open sooner (86C rings a bell for the current one). Any other ideas?
    Thanks in advance
    I have been pruned by old man river!!!!!
    Default Re: 4agze temperature issues
    you and Vito should sit down together...
    Jul 2007
    I lol'd
    Try pulling the plug off of the thermo switch so that the fans stay always on, see if it makes a difference.
    After that, things start getting harder...... much harder
    The thermo fans work well and the temperature is stable on your normal 25C days even in traffic. But today with 30+C and stuck in traffic it didn't seem to do the car any good. As soon as she started getting through traffic the temp came down...same thing happens on my ae82 so I gave her some pointers to avoid start/stop drivng in 1st but leave a large enough gap to shift into 2nd or even 3rd and get the airflow going.
    What have you tried Vito?
    Sep 2008
    Do the dodgey and drive round with the heater on full
    The GOD HAND AW11 - sold
    Victoria, Mt Macedon
    Afraid I can't help with remedies, but rest assured it takes alot of heat to damage a 4AGZE. I drifted mine well into the red zone of the temp guage (110+ deg according to the ECU) far too many times (when I got carried away) and the thing didn't show any ill effects after 3 years.
    Hen
    Jul 2007
    Quote Originally Posted by Dimmy View Post
    recoed radiator, drilled out thermostat, flushed and bled coolant too many times to remember, heater on full all the time, thermos on all the time. if all of that doesnt fix it... then you have serious issues.
    wow...you really have tried alot I don't think it's having "issues" as such since EVERY single 4ac, 4age, 4agze i have ever driven has heated up if stuck in traffic on a hot day, but I don't want her to get stuck somewhere some time just because the car overheats
    I can imagine running the heater on a 35C day haha. As i said, on 25C or so days even in traffic it doesn't have a problem. Coolant is fresh, thermostat is good and no radiator issues that I am aware of.
    Aug 2009
    tried using a radiator cap over 1.1bar and a bigger more efficient set of thermo fans that come with a temperature controller....
    also id recommend installing a water temperature gauge on the inside of the car so you can gauge it accurately instead of saying hmm its 5mm off red lol
    Jul 2007
    oh i forgot to mention testing the thermatic switch in hot water, as well as testing the thermostat in hot water. done them too.
    if you dont mind being a bit dodgy, drill three little holes in the thermostat, and see if the car still overheats. the holes mean you always have some coolant flowing through the radiator before the car gets hot enough for the thermo to open up. it is dodgy though as it means the car takes heaps long to warm up especially on cold days, which is not good. but for troubleshooting it can be useful to find the bottleneck in your cooling system.
    you should then replace the thermostat for a non-drilled one once you have finished troubleshooting
    Aug 2009
    and if that IS your problem vito wants to buy that thermostat off your for his car LOL =P
    you could always try looking around for a lower temperature thermostat?
    Jul 2007
    test and then drill the thermo first to see if it helps. if it isnt buggered, and the extra holes help, get a lower temp thermo. if it doesnt help, a lower temp thermo aint gonna do much for you is it.
    and shaddup
    S.A
    You dont have a partially blocked radiator do you?
    It can be fine on cooler days and show no signs of a problem but when the temp gets up there on hotter days issues can arise with the system unable to cope.
    Might be worth a look in...... have seen it many times before
    Unfortunatley..... the only way to tell is to take the radiator to a specialist to check it. just looking down into the fins wont tell you shit.
    Jul 2007
    One of my many problems was a partially blocked radiator Car is still being gay though
    As I said Dimmy, after you do the simple shit with the fans and the thermostat it gets harder.... next step would be the radiator as 30psi4agte said
    edit; heres a checklist I prepared earlier
    Coolant leaks/Airlocks
    Check the thermostat housing for leaks (I've had 2 brand new o-rings fail) Check heater hoses and radiator hoses etc. Bleed coolant
    Dead water pump
    Check coolant is flowing, check waterpump isnt leaking from the drip hole
    Thermostat not working properly
    Check thermostat operation according to BGB
    Thermofans not working properly
    Check thermatic switch for resistance according to BGB
    Timing retarded
    Check with timing light. (dont really need to, unless you can tell by seat of pants that it doesnt feel right, then check timing)
    Blocked radiator
    Check heat of hoses in/out of radiator. Pull it out and take it to a radiator shop. Flush block and lines.
    BHG
    You are now fucked
    hmmm...thanks for the input guys. I know there are no leaks, the water pump is working well and so is the thermostat. I may have to get the radiator checked, because I'm not 100% sure on that one.
    Has anyone every put in a 2nd 4age style fan and spliced the connection into the existing fan for power? Tight arse way of having "better fan" cooling, but it will tell me if I can fix the issue that way
  1. can other 4AGZE blocks be used with AE101 loom (essentially)
    Last Post: 07-02-2007, 06:23 PM
  2. 4AGZE in to 4AGE AE82. (now with CV shaft info)
    By Striker in forum Tech and Conversions
    Last Post: 28-12-2006, 02:53 PM
  3. 4agze temperature issues????
    By 4AGZE_rolla in forum Tech and Conversions
    Last Post: 04-05-2006, 10:08 AM
