Factory wiring, or something you've changed?
If its something you've changed then look over the diagrams, normally there are 2 fuses that supply the engine/ecu/components.
The EFI fuse does one lot, and the AM2 fuse does another lot.
You've possibly wired the whole engine up to the EFI fuse, and the injectors/ignitors/coils are blowing the fuse (they are generally powered from elsewhere, such as the AM2 fuse via the circuit opening relay).
