Page 19 of 19 FirstFirst ... 9171819
Results 271 to 281 of 281
Thread: Official Hello and Welcome Thread.
  1. #271
    Feb 2018
    Default Re: Official Hello and Welcome Thread.
    Hey guys.
    I’m Cameron I’m 25 and I have a 1991 uzz30 Toyota soarer burnout car.
  2. #272
    Apr 2018
    Hi everyone.
    Al from Newcastle here.
    I have become sick of fixing my Bimmer every week so I thought I'd have a change of scenery and fix something else every week. Looking at buying a factory 4AGE Corolla over the next few months and thought joining here to ask a few questions would be a good start.
  3. #273
    Apr 2019
    Hey Guys, Just joined today and loving the info on this forum.
    Previously owned many Corollas, KE20s, Ke30, KE70s and SX Liftback.
    My recent project is KE70 Corolla. Currently very stock while it gets a full resto.
    Can’t wait to hit some events and cruises.
    Vince
  4. #274
    Apr 2019
    Kaiapoi
    Hello all
    Johnson Keast is my name from Christchurch New Zealand.
    Cars owned:
    4age ae71 Toyota Sprinter
    z18et datsun 1200
    4k turbo ke30
    4afe toyota corolla 1984 front wheel drive shitbox
    rb20det r32 skyline
    rb30et c33 nissan laurel
    Currently working on:
    Toyota Chaser 1984 1gge tvis air flow meter model having major issues with injector pulse that I will post about in the appropriate locations (been on this for a year and have not solved it)
    Just happy to have finally found a great forum by the looks with plenty of Toyota people
    Have a good day folks.
    Kind regards
  5. #275
    Mar 2019
    Northland
    giday,
    im Warryck, i live in northland New Zealand,,
    bought my first corrolla gt in 87, had 25k on the dial, 4AGE Hatch
    traded it for a hiace diesel! well things change!
    diesel vectra! 1.7l would do 160km/h, eventually,
    and if you hung around 95-105km/h yoiu will get 52mph.. but was isuzu powered ..
    have 2lte cruiser,
    bought a 89 mk2 2ltd, still have after reconditioning the motor..
    latest is a 92 cressida, been sitting for a year with a damaged head gasket,
    so now have a 1jz gte vvti standard auto installed,,
    which has me looking about for like minded toyota guys, (and gals)..
  6. #276
    Dec 2019
    NC
    My name is Michael Yount - I'm retired in Charlotte, NC, USA. Glad to connect with other vintage Toyota fans across the big pond. Back in the late 80's I raced a '74 Corolla TE27 in Sports Car Club of America. Since then, I've wanted another and recently came across a really clean, restored TE21 in Texas. Picked it up in November, 2019. The previous owner did a great job on the BIG stuff - paint/body/interior/drivetrain. However, there are a lot of little details that need attention -- working on those now. Looking forward to re-educating myself about these cars - and learning from you folks.
  7. #277
    Mar 2019
    California
    Quote Originally Posted by Michael Yount View Post
    Looks awesome Michael! Cant wait to see your build. Looks like you already have a lot done and hopefully only minor junk to contend with.
  8. #278
    Dec 2019
    NC
    Thx Dragon! Here's where we are so far....
    1) **Explore brake booster**
    2) Brake M/C heat shield
    3) Relocate battery to trunk
    4) Relocate fuel tank under trunk floor
    5) **Balance Carbs**
    6) **Explore timing - including vacuum advance - done, 20 degree BTDC initial, 14 degrees centrifugal, 15 degrees vacuum**
    7) Fix or replace speedo
    8) **Explore tach accuracy** (done - 6 cyl switch was selected instead of 4 cyl switch)
    9) **Explore turn signal self cancelling** --- not sure what to do here - an entire mechanism is missing
    10) **Set front toe**
    11) **Fix steering column plastic piece that holds the tach**
    12) **Fix/replace the plastic interior door handle surrounds.**
    13) **Adjust headlights - Euro E-codes -- set horizontally straight ahead; vertically 2"-3" low**
    14) Fabricate Panhard Rod
    15) Fabricate Strut tower/firewall bar
    16) Headlight relays - 1 for low beam, 1 for high beam (may not need -- only .5V drop from battery voltage)
    17) **Tune carbs/idle air mixture**
    18) Electric Cooling Fan
    19) Catch can
    20) Check A/C function
    21) **Check (replaced) spark plugs and valve lash**
    22) **Install toggle/relay for back Up Lights**
    23) **Explore stereo Function (on/off)**
    24) Explore hidden stereo antenna
    25) **Repair coolant leak into interior** (heater core repair and service heater control cables)
    26) **Replace Thermostat**
    27) **Repair sagging lower driver's seat bolster on left side**
    28) **Reposition seat rails for a bit of extra leg room**
    29) **Common vacuum rail across all 4 intake runners**
    30) Fuel level gauge accuracy
    31) **Install 7" Cibie European E-code headlights**
    32) **Oil/filter change**
    33) **Center tail pipe in rear valence cutout**
    34) **Adjust tension rods to set wheelbase**
    35) Upgrade Alternator (https://www.toymods.org.au/forums/th...rnator+upgrade
    36) **Replace Weld Racing wheels/tires with "minilites"**
    37) **Lower car 3/4"**
    38) **Koni dampers on front struts**
    39) Fabricate front air dam
    40) Weld/smooth bumpers
    41) **Replace brake hoses front and rear**
    42) **Replace tranny fluid, diff fluid, brake fluid, hyd clutch fluid and coolant**
    43) Reduce spring rate - rear leafs
    **= Completed
    '16 Subaru Crosstrek; '17 Mazda3 Hatch; '82 Volvo 242 w/LS3 V8 power; '73 TE21 w/3TC power
  9. #279
    Dec 2019
    G'day everyone! Liam here.
    For the last ten years or so I have owned a 1989 Corolla SX hatch. Up until last year it was my daily drive. She has picked up a few bumps and scrapes in that time, but over all was a very reliable car to get around in. I have kept the car pretty much stock. Ithese things have so much character that modifying what is already a unique vehicle has never been much of a temptation for me. The goal is now to preserve and maintain now that I can avoid shopping centre car parks, and when the world gets back to normal hopefully get out on a cruise with some of the members of this forum! Cheers :)
  10. #280
    Sep 2007
    Long time lurker, first (ish) time poster
    Joined the sheep and i have myself a GR Yaris, as well as a couple of JZA80's (I was in half of the wisemans run until my son got sick and we lagged behind)
    Wow - just saw my join date..!! Sep 2007
  11. #281
    Nov 2023
    Hello.
    I'm Chris. I've recently gotten back behind the wheel of a Corolla. I managed to buy a bucket list car, KE15 Sprinter with a 4AGE swapped in. I had a deposit on a GR86, but when this popped up, it was too good to say no to.
    It needs some work to get back on the road, but I'm very chuffed.
    Chris
    Sent from my SM-G986B using Tapatalk
