Results 16 to 29 of 29
Thread: What should a novice put in a TA22
    Default Re: What should a novice put in a TA22
    My tafe teacher has something like 170hp out of his mechanical injected 2t in his sprint car and is n/a the kent knows his shit about the 2t single cam motor!
    SLEEK22 1st year Apprentice TA22Celica's Avatar
    Jan 2009
    Quote Originally Posted by NME308 View Post
    The old 2T is extremely under rated!
    If it is still in reasonable health i.e. not blowing smoke etc, my vote would be leave it there!
    My first celica had the 2T on board and it was a blast!
    It got a 25-65 Ivan Tigh cam (friggin NO idea what those figures mean) which lumped away nicely at idle, a slight shave of the head to give 10:1 compression, a 350 holley carb, and a set of extractors mated to a 2 inch 'sports' exhaust. I could outrun all my mates with bombed 6cyl early commodores both over the quarter and top speed, plus it pulled gnarly slides into 2nd gear when you were giving it a hard time! Long before the term was known I was doing drifting with the thing as well as dirt rallying etc... Made the trip from Rocky to Mt Tamborine in 5hrs i.e. pulled quite a few revs for quite long periods!
    A 2T built in this way and treated as described above should almost survive your P plates at which time it will be worth thinking about that turbo upgrade!
    My 2c worth,
    Jason
    Agreed the 2T is very underated, slap a turbo on it (when off P's) and hold on
    Trent
    TA22 Celica Airbagged 2T-Turbo !!OUT!! 3TGTE in
    TA22 Celica_Parts
    84' Hilux Fully bagged_notched_Fully custom 4-Link_Throws Sparks
    Datto 1000_with worked A15
    Oct 2009
    Bowmans Forest, vic
    Lol, for some reason the hemi and booze seems like such a good idea
    Well im still going for a 2TG but if i cant track one down in time i'll mod up the 2T. i doubt i could get 170 out of it but hell, it'd be fun trying
    Thanks all!! now to get on Ebay
    "if everything seems under control your'e not going fast enough"-Mario Andretti
    Don't forget you can always go to the Classifieds section on these forums, and post in Parts Wanted, for a 2T-G. Maybe a fellow Toymodder has one?
    seeyuzz
    river
    Oct 2009
    Bowmans Forest, vic
    Yeah i will, just gotta make sure i have a TA22 first, cause if i end up with a RA28 (or something) and i have a 2TG for it......... well crap
    Webber carb and extractors and zorst on the 2T! Load of fun if set up right.
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    A healthy 2T is a shitload better than a 18-Rc.
    A 18r is a small boat anchor.
    A 2T+Webber+Extractors and exhaust is the shiz for the old22.(sounds like a small aircraft on the freeway).
    A 3tgte would be good,a tops engine but super old and expensive to rebuild. A 1G for an IS200 would make a very cost effective upgrade.
    Case
    What is it with people assuming that because an engine doesn't have a turbo, that it's P Plate Legal? FFS people, P Platers cannot drive a vehicle that has a "modified engine". Just because the engine is stock, doesn't mean it's not a modified engine when it's put into a 70's Celica!
    Hell, why not put in a 3.6L 210kw Holden V6 in a 70kg KE20... It must be P Plate Legal because it's a stock engine.
    ([][][]II--LT--II[][][])
    Quote Originally Posted by YelloRolla View Post
    NME308 those figures mean that the intake valve opens 25 deg BTDC and closes 65 deg ABDC, your exhaust valve opens 65 deg BTDC and closes 25 deg ATDC. Total duration therefore = 270deg and you will have 50 deg of valve overlap.
    These numbers are theoretical and truly apply if you set them up that way (IE your valve lash is set correctly and your cam is timed in the correct position).
    Ahhh... Thanks YelloRolla! Duration and overlap figures I do understand!
    Quote Originally Posted by RAAAH23 View Post
    and never blew a diff?
    My bad... Thought we were just talking engines!
    1 x Blown diff
    1 x Blown gearbox
    2 x busted uni's
    1 x shagged clutch
    Better factor in some extra pocket money if ya gunna drive like a total idiot!
    Jason
    T'ville, QLD
    just 3vz it, all the cool kids are doing it.
    chances are ill get mine running and sell it in favour of a bigger and better engine lol, engine conversions are easy, but time consuming and expensive, just keep the 2t in there, i know i sure as fuck should have
    2T out 4A in....
    Hey Skiddz,
    If you really want it, I have your 2T still sitting here
    Dave
    T'ville, QLD
    do you really still have my old 2t dave?
    you've had that almost 3 years, glad to see its of good use, worlds most expensive door stop (was it $50? i cant remember)
    2T out 4A in....
    Quote Originally Posted by skiddz View Post
    Hehe, yeah its still sitting there.
    I did buy it just for spares for my red ones 2T though.
    All in good time
    Dave
    Apr 2007
    I'm onto it now LRP
    Case
  1. Ta22 Idler Arm bushes
    By ThaNav in forum Tech and Conversions
    Last Post: 31-01-2009, 12:05 PM
