Results 46 to 60 of 61
Thread: LSx and 1UZ comparison & dimensions
  1. #46
    Default Re: LSx and 1UZ comparison & dimensions
    Quote Originally Posted by TA22 1MZ View Post
    There are plenty of cars getting around or in the build that are overcoming the weight restriction. Would love to know how!
    If so, NA would need a car weighing 1900kg and FI would need 2280kg
    Not if the car was a 6 Cylinder The weight calculation changes if it had more than 4 cylinders from the factory.
    http://www.rta.nsw.gov.au/registrati...s_nov_2007.pdf
    More than 4 cylinder vehicles with a seperate chassis get:
    NA - In millilitres (cc):
    Original tare mass (kg) x 5.46
    FI - In millilitres (cc):
    Original tare mass (kg) x 4.68
    Mono Constructed more than 4 cylinder vehicles get:
    Original tare mass (kg) x 4.82
    Original tare mass (kg) x 4.0
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  2. #47
    That LS would look alright in my 2WD Hilux and no doubt a heap easier to fit than the UZ i have
    Let me know if you find a cheap LS supply Justen.
    The 1UZ into the Crown ute seems to be loaded with compromises.
    cheers Chuck.
    MS51Crown Coupe,
  4. #49
    Quote Originally Posted by Hiro View Post
    That's because 90deg V8s aren't exactly condusive to compact FWD layouts. That, and it is basically a 2.5L Duratec V6 with two extra cylinders grafted on.
    thats because FWD is the devil's work.
  5. #50
    oh...before i foget, Jack,
    have you tried resting the motor in place with the starter motor bolted into the block? as thats one thing i notcied in a customers car that the stater motor sits quite low and wide.... maybe an issue fowling on the rack?
    and does the front sump version clear a ta23/ke70 style cross member?
  6. #51
    Victoria, Mt Macedon
    Can someone please change the title of this thread to "LS1 > 1UZ"??
    Last edited by Hen; 22-10-2009 at 08:05 AM. Reason: Used please twice. Like, let myself introduce.... myself.
  7. #52
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    Quote Originally Posted by IN 05 NT View Post
    I believe there are two styles of starter motors Blake. The one I have is very small and compact. I will fit it up and see whether it fouls on the steering rack.
    The front sump does fit the KE70 cross member well, HOWEVER the engine sits quite forward, so depending on how pedantic you are about weight distribution would determine if sump mods would be required to get the engine back.
  8. #53
    Quote Originally Posted by Hen View Post
    Now now Hen, my intention with this thread wasnt to put crap on the 1UZ, it was purely to provide useful information for those who are torn between the 2 engines
  9. #54
    I am feeling suitably inadequate right now.... :-( Seeing as I bought a 1uz...
    Facebook | LinkedIn
  10. #55
    Quote Originally Posted by stradlater View Post
    Why? per CC the UZ is still clearly the better engineered engine. It's just hard to argue with the cubes of the LS. Once they improved the quality of materials they are made from so they hang together a bit better and got some weight out, they became (in my book anyways) a real alternative.
    A little like the argument between all motor and turbo...some say one is the blunter tool but jeez it gets the job done
    Nov 2007
    For anyone who wants some more dimensions of the 1UZ i found these the other day in my travels.
  12. #57
    If you wan't to switch to a LS#, then I know someone that would be interested in buying the 1UZ of you...
    ([][][]II--LT--II[][][])
  13. #58
    I think if you looked around you'd find numerous other manufacturer engines that have advantages over the equivalent Toyota one, and of course the reverse is also true (hence UZs/JZs finding their way into all sorts of vehicles)
    I personally dont care how much power or how easy it is to get from an LSx because id never put GM pushrod junk into my car. I also admire an engine conversion from the same manufacturer over an engine from someone else... maybe thats just me :shrugs: Its like LS-powered RX-7s: regardless what you think about rotarys (and i dont care much for them either) its just somehow not right to do it!
  14. #59
    Jun 2006
    Quote Originally Posted by andrew_mx83 View Post
    ford also have a 60deg v8 as used in the US only taurus SHO.
    not sure what angle the cosworth dfv was....
    I have half a feeling that the Taurus V8 may have some Yamaha DNA.. There was also a FWD V8 in Volvos a few years ago... not sure if it was just the Ford unit rehashed, or a Volvo only unit... (Ford owned Volvo at the time).
  15. #60
    Jan 2008
    queensland
    Depends what you want from the car, if you want it to go hard then the LS engines win hands down,smaller lighter and more grunt end of story, but if you want to keep it all in the family then yes the 1uz is the logical engine for a toyota,but i think there is merit in picking what you want in a car and going out and finding it no matter what brand it is, look at race cars like V8supercar they are either holden or ford badged but apsolutely nothing on them is manufactured for the road going versions in AUS, If it does what you want and makes you happy then DO IT i say, I chose a 1uz for my Hilux for the reliability and V8 factor that only V8 drivers know,the fact that its a toyota engine is a bonus.
