Results 1 to 2 of 2
Thread: 1jzgte main cap torque
    Mar 2009
    Default 1jzgte main cap torque
    Hi guys i have been searching for ages and cant find the torque settings for the crank main caps i would go out and buy a manual but i only need these specs, any help appreciated
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default Re: 1jzgte main cap torque
    Better late than never
    Originally from Supramania http://www.supramania.com/forums/showthread.php?t=42823
    some 1jz Torque Specs:
    - head bolts = 25 ft lbs mark ft of bolt and go another 90 x 2, 180 degrees total
    - connecting rod caps= 22 ft lbs mark and go another 90 degrees
    - main bearing caps= 33ft lbs then mark bolt and go 90 degrees farther
    - cam bearing caps= 14,ft lbs in three passes
    - inner timing belt cover= 78 in lbs
    - cam gear bolts = 59 ft lbs
    - valve cover bolts = 74 in lbs
    - inner intake manifold 7 bolts =20 ft lbs
    - fuel inlet pipe= 30 ft lbs
    - exhaust manifolds 29 ft lbs
    - turbos= 40 ft lbs
    - rear main seal plate 6 bolts = 52 in lbs
    - upper oil pan #1 oil pan 22 bolts/12mm bolts= 15 ftlbs,14mm bolts= 29 ft lbs
    - turbo outlet pipe 2 nuts= 20 ft lbs
    - oil pan baffel plate 5 bolts,2 nuts= 78 in lbs
    - oil pickup = 78 in lbs
    - #2 oil pan lower pan 16 bolts 2 nuts= 78 in lbs
    - oil pump 9 bolts 15 ft lbs
    - inner water pump housing= 15 ft lbs
    - water pump 15 ft lbs
    - flywheel M/T 8 bolts 36 ft lbs then mark bolt and go another 90 degrees
    - flywheel A/T 8 bolts 61 ft lbs
  1. gear ratio's, torque, dyno's,
    By WhiteSx in forum Tech and Conversions
    Last Post: 22-09-2009, 01:08 PM
  2. Genral Metric bolt torque
    By ra_28 in forum Tech and Conversions
    Last Post: 16-09-2008, 05:00 PM
  3. 1JZ bottom end torque specs
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 11-06-2006, 10:51 AM
  4. Torque setting for the hub nut 86 AW11 MR2
    By Chubs in forum Tech and Conversions
    Last Post: 07-03-2006, 04:30 PM
