Results 16 to 20 of 20
Thread: 4agze boost problems
    Genuine Hotty. Conversion King old_mr2's Avatar
    Default Re: 4agze boost problems
    update:
    Car has bee to the dyno. Basically the car is leaning out when the problem occurs. Spark is fine.
    ECU is now throwing out code 43 after an ECU reset. The ChkEngine light comes on now after about 10 minutes of driving and problem starts pretty much straight away.
    43 Starter
    * No starter signal to ECU when cranking in TEST mode. Terminal STA on ECU
    * starter signal circuit
    * starter relay
    * ignition switch
    Can anyone suggest which of the above suggestions could relate to the car leaning out?
    anyone?....
    Well the fault has been resolved. An earth continuity test revealed an earth leak. An earthing pin was not secured properly to the chassis (out of sight and totally unrelated to the recent work done on the car)
    After the car warmed up, the weak earth messed up my AFR causing the lean out.
    Woot, car is now ready and healthy for the MR2 Bathurst Nationals!!!
    Sep 2008
    good work old!!! great to hear
    The GOD HAND AW11 - sold
    Faulty ECU leaking Caps?
    I checdked this before you posted actually. ECU looks like it just rolled out of the factory. All components appear to be as new.
  1. ae 101 4agze turbo problems
    By fraser in forum Tech and Conversions
    Last Post: 26-11-2008, 06:52 AM
  2. Guide to Boost, Octane, and CR
    By Radar in forum Tech and Conversions
    Last Post: 03-05-2008, 09:21 PM
  3. 2jzgte - strange surging boost when cold
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 15-04-2008, 10:56 AM
  4. 4AGZE mechanical boost gauge
    By Skein in forum Tech and Conversions
    Last Post: 31-10-2006, 12:09 PM
  5. a few questions and problems 4AGZE
    By Pr0j3kt_SuPrA in forum Tech and Conversions
    Last Post: 20-07-2006, 09:26 AM
