I've been trying to sort this out myself for a while now on my project AE86.
Matching RA40 coilover-converted struts to AE86 control arms,with 45mm RCAs and getting big brakes in there under a 15x7.5" -8 wheel,and making it all clear nicely hasn't been easy.
I gave up on using nissan callipers as the brackets required would be extremely complex,and a 30mm disc just won't fit. Noone's going to want to machine down the sumitomo callipers to suit the thinner disc,so the R32 GTS-t callipers I have on hand aren't going to be any good.
the widest disc I could get to fit in was 22mm thick,a Z31front,which is 280x22.
the calliper I ended up choosing as it will fit in once brackets can be made was a spoon 4 pot for the DC2 Integra. these aren't cheap unfortunately,about $1400/pair. the pads are easy to get though,in any compound you like,so living with them once they go in will be easy. easier than something like a willwood,which was my previous choice.
I might be able to get an AE86 hub and an RA40 hub out of storage sometime this week,and I'll post the measurements if I can find them for you.
I DO remember that the RA40 hubs are bigger in diameter and are both taller and wider in the hub and bearing areas respectively,when compared to the AE86 hubs. I'll put numbers to that when I get a chance.
Justin...
