Results 1 to 12 of 12
Thread: e58 gearbox fluid(s)?
    Sep 2009
    Dalarna
    Default e58 gearbox fluid(s)?
    My e58 transmission was emptied of all fluids when I bought it and I need to fill it up.
    Do I use one fluid for the gearbox and an other for the LSD?
    How much fluid would I need?
    Sep 2008
    Default Re: e58 gearbox fluid(s)?
    Get
    2 bottles of penrite limslip 90
    (Smurfs blood)
    Takes about 4.3 litres but the best way to tell is to open up the filler plug (should be located on the bottom side) and fill it till it comes out of there...
    The GOD HAND AW11 - sold
    Gearbox and diff share the same oil right?
    Using diff oil in a gearbox cant be a good thing
    FWD
    10 chars
    Sep 2009
    Dalarna
    Get
    (Smurfs blood)
    Ok so it's only one type of fluid I need? ...a gearbox oil with limited slip additive if I understand it correctly?
    Chiba
    I use Royal Purple Max Gear 70W90 in my LSD E58 to excellent effect. I know the synchros are stuffed (oil came out like metallic paint) but with a refill of RP, it now shifts with only a minor notchiness. I've probably got another 30,000Kms out of the box so far.
    Costs a bit though......
    Im going for a PPG (Pfitzner Performance Gearbox) factory tour on Monday, itll be interesting to see which oil they recommend.
    Sep 2009
    Dalarna
    Factory tours rock! I envy you
    dont use an oil with an LSD additive... its a torsen centre.
    Some good old Castrol VMX80 will work well for a cheaper option.... or a quality sythnetic gear oil.
    Oberst Koi-Master Backyard Mechanic
    Been using redline lightweight shockproof (light blue muck) in my e58 since the conversion was finished back in 2004/5... never skipped a beat, never glazed the synchro's as has happened to 1jz owners on here.
    "Welcome the dude who ain't the buyer of mugs"
    Sep 2008
    penrite limslip 90... thats all you need!
    Sep 2009
    Dalarna
    Thanks all you guys!
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Verifying a w58 gearbox
  3. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    Last Post: 27-12-2006, 06:22 PM
  4. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
