Results 1 to 4 of 4
Thread: AE86 upper trailing arm length
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    Default AE86 upper trailing arm length
    My mx32 Cressida rear upper trailing arms are stuffed and i cant fit my new bushes I found this out today when getting a RWC so i need this to get my car on the road and the car is at the mechanics now
    the length from hole to hole is 280mm.
    Does anyone know the messurements of AE86 upper trailing arms? please
    [Gentlemen's Club]
    oregon
    Default Re: AE86 upper trailing arm length
    AE86 upper trailing arms are 245mm
    May 2006
    Thank you yeah it was urgent and i have just orderd ae86s upper whiteline arms as they can be adjusted to the same length but then i just found out that they have a 12mm bolt hole and not a 14mm bolt hole
    so im stuck and now have ae86s whiteline upperarms that i can not use
    [Gentlemen's Club]
    oregon
    Quote Originally Posted by HIZOKU View Post
    I believe the Whiteline bushings are poly... and use a steel insert/sleeve. Either see if you can get the sleeve drilled, or get a sleeve w 14mm on the inside
  1. Adjustable upper or lower trailing arms?
    Last Post: 01-05-2008, 08:03 PM
