Results 1 to 8 of 8
Thread: Sc14
    Aug 2009
    Default Sc14
    whats involved with an SC14 and how does it operate.. just wondering has it got a magnetic clutch and is it controlled?.. can you bypass it?.. how easy is it to adapt an SC14 to a non toyota engine?
    any help would be good thanks
    User Conversion King
    NWA
    Default Re: Sc14
    an SC14 displaces a fixed volume of air per revolution; minus leakage.
    have a search im sure this stuff is well detailed on here
    hello
    Aug 2009
    Default Re: Sc14
    k ive found a little information thanks to adsports post..... still wondering if its got a magnetic clutch on them or is that only some models?
    and whats the ABV ?? im assuming air bypass valve?... does it work off inlet pressure or something?
    Junior Member Grease Monkey minimechanic's Avatar
    Default Re: Sc14
    everything u need to know is in this thread!
    it's not too hard to mount up the sc14.. just make up a few brackets here and there..
    i chucked an sc12 on my mini.. a friend put the sc14 on his r31 without too much screwing around..
    lucas
    Aug 2009
    Default Re: Sc14
    thanks dude... just wondering about the magnetic clutch thats all
    perth
    Default Re: Sc14
    its a magnetic clutch like an A/C, switched on with 12v (and 8-10"hg on gze ecu) you can take the pulley off if you like and get one machined up to replace, i cant remember how many teeth the main shaft has on the blower.
    the abv is on the pressure side of the blower and bypasses the air over a preset pressure.
    need pix ? i can take some.
    Default Re: Sc14
    sorry dude..
    forgot to post up the link to the thread i was talkin bowt.
    http://www.toymods.net/forums/showthread.php?t=8688
    I went to go buy a Where's Wally book the other day..
    couldn't find it anywhere..
    You win this round Wally...
    MX83 + 2JZ + R154
    Default Re: Sc14
    The clutch for SC14 is damn hard to find nowdays. You have three options for the clutch (if you need one), you can either build an adaptor plate and mount an SC12 clutch failry cheaply/easily, buy an aftermarket pulley from the Pulley Bros or other retailer and lastly ditch the clutch idea and build a custom pulley to run the SC full time (can provide pics of option 1 and 3 if interested).
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 12:02 AM
  2. my SC14 fitting guide
    By Adsport in forum Tech and Conversions
    Last Post: 05-01-2011, 11:04 PM
  3. 4agze with sc14
    By uniquetrueno in forum Tech and Conversions
    Last Post: 01-10-2009, 12:24 PM
  4. 2TZ SC14 pulley onto 1G SC14
    Last Post: 16-09-2009, 08:07 AM
  5. Anyone using a Previa SC14 on a 4A?
    By turbo4agte in forum Tech and Conversions
    Last Post: 15-09-2009, 02:38 AM
