Results 1 to 9 of 9
Thread: JZA70 & JZZ30 chassis
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default JZA70 & JZZ30 chassis
    I was told by a local performance shop that a JZA70 and JZZ30 chassis are the same.
    Could anybody clarify this.
    Reason being i'm getting a 1jz soarer halfcut and was hoping i might be able to use the crossmember in my GA70
    Thanks
    Default Re: JZA70 & JZZ30 chassis
    Your local performance shop has got nothing.
    JZA70 shares floorpan with *Z20 soarer, not *Z30.
    Get a JZA70 halfcut for your ga70 and bolt the subframe into your car.
    Thanks for the advice. Thought somin sounded out of place
    Junior Member Backyard Mechanic manny's Avatar
    He may have meant JZA80??
    JZA80 uses a shortened JZZ30 floorpan.
    GSE20 IS250 - daily
    Junior Member Backyard Mechanic nihilism's Avatar
    a70 and z20 are similar, same suspension etc.
    a80 and z30 are similar, same suspension etc.
    AFAIK A70 and Z20 are more than similar, they are near identical....
    Rails are the same length and width, sill panels are the same, suspension is the same, front and rear subframe are the same as well, exhausts are not as the Z20 exhaust is about 120mm longer
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Quote Originally Posted by nihilism
    a61 and z10 are similar too.
    Cept the Z10's wheelbase is ~1" longer.
    funny how toyota used the furtherst apart letters in the alphabet
    A chassis started in the late 60's? early 70's?
    Z chassis didn't start until 1981.
    So they weren't built alongside each other.
  1. Hilux Diff Centre - JZA70 Torsen Installation
    By Pure_In_Sanity in forum Tech and Conversions
    Last Post: 05-12-2011, 08:52 AM
  2. MA70 --> JZA70 Conversion
  3. Bending downward 4cm of 1 side of a xA6x Chassis HELP ME !!!! :(
    Last Post: 03-01-2006, 05:56 PM
