blake: The only common point between the two setups would be the upper mount points for the shocks. No idea if the chassis rails at the rear are the same for RA60 & 65/61 but it's them not the floor that you'd have to swap over as the mount points are attached to the chassis rails not the floor.
Have you thought about stuffing a JZA70/MA70 rear end into this thing (Crambo has done it and the TA64 rally car up here has as well). Room in it for a substantial diff and the axles are quite robust. You'd also have the handling benefit of a proper IRS rear-end.
Two of the mount points on the JZA70/MZ70 subframe line-up with the MA61 chassis and you only need 4 out of the 6 points to attach it.
Is anyone breaking them? Having seen one survive hell at Dubbo laying down 400rwkw via slicks i'm glad i finally added the last piece to mine.
