Results 16 to 23 of 23
Thread: 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    Equipped with Bowls Hat Backyard Mechanic Adam_Cressi's Avatar
    Default Re: 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    when i said small port TVIS, i meant it was a bigport, with smallport rocket covers.. which is what toyots released, but in small numbers. NOt sure of the internals but yeah .. i have owned all 3 so i know i little bit bout them all
    2JZ-GTE MX-83 Cressida
    Toymods Car Club Club Member # 185
    cam covers - the worst way to determine what a 4AGE is ever.
    i think teh colors are different, they are different between my smallport AE92 engine and my mates RWD redtop TVIS engine.
    so jezz, they dont have adjustable cams? i think the factory cams have some adjustability (2 positions) but im not sure how they work.
    tell craig to run something better than "unpremium" unleaded and you should be able to put more timing in
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    They dont have adjustable cam gears....i just through them in there in the same positions as the old ones.
    GL getting craig to run anything with the word premium in it.
    Jez
    Junior Member Grease Monkey craigy's Avatar
    Premium is 5 cents a litre more than standard unleaded! Screw that! hehe
    Thanks for the supplying the info Jez, and the use of your shed yet again! and might I mention that I was working under the car like a bitch while jez changed the cams and got all the glory! lol
    And yes it was a totally spare if the moment thing, Im taking this particular engine out after next week.
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    Another question, how much are the cams from crow?
    dan
    Dont know, bought them second hand.
    Let me know if your interested, i'll be selling these in a couple of weeks
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    I dont like the term Grease Monkey beige_bandit's Avatar
    A.C.T
    I didnt say anything about smallport with tvis!
    I just wanted to know for the third time exactly what setup these cams are in!
    But anyways
    Im just a little lost but ill be fine!
    Quote Originally Posted by Rallystanza
    Okay.
    I installed the cams into Craigs engine and played with the timing afterwards to gain this big improvement.
    The engine is a BIGPORT TVIS 4AGE and the Block is a 7 RIB jobby.
    As far as this 7 RIB BLOCK containing the larger crank I am not sure.
    The Cams are a Crow Cams item.
    The inital timing when installed was 5 Deg BTDC. Ran fine, had no more power, prolly much less. Idle was a bit rude also - too low.
    I then upped the timing to the 4AGE factory manual spec of 16 Deg BTDC with testing terminals unbridged.
    This is where the tioming sits at the moment.
    Will possibly put some more timing into it but for the time being, the idle is great (Phat) the revs are smooth and there is no pre-ignition.
    Will keep you posted, seeing as craigs shed is my shed!
    Jez
    Can you read?
    Or have i missed something?
  1. The 1UZ Mods Thread
    Last Post: 11-05-2014, 07:19 PM
