Results 1 to 2 of 2
Thread: Mx62 cressida conversion
    tas
    Default Mx62 cressida conversion
    Im thinking about buy a mates car ive been borrowing, pretty cruisey car,
    But the power it has is pathetic, Being an m series engine will any other m series engine bolt into its place using factory mounts, also powersteering bracket and alternator will they bolt onto this a 7m as such.
    When converting to manual with these cars what clutch pedal/pedal box is a good fit, I know with mx73's you can use an ma61 pedal for instance,
    I suppose the mx62 is the ugliest brother of the cressida models but its starting to grow on me for sure and there doesnt seem to be many modded ones about the place
    cheers Josh
    Default Re: Mx62 cressida conversion
    Grab a whole 7M if that's the way you want to go. 5ME PS pump and alternator don't bolt up to 7M...
    5me engine mounts, sump and oil pump will on the 7M however
    GX61 pedal box would fit in, if you can find one Otherwise I modded xA6x to fit in mine...
    MX32 auto gearbox xmember is perfect W5x gearbox into MX62.
    W5x gearbox position I would recommend MA70.
    Wilbo's JZA80
    Wilbo's JZZ12
  1. 1j in cressida conversion.. what to look for?
    By rshuwy in forum Tech and Conversions
    Last Post: 03-08-2009, 03:27 PM
  2. MA70 --> JZA70 Conversion
