Results 1 to 13 of 13
Thread: 2jzgte injectors
    Sep 2009
    queensland
    Default 2jzgte injectors
    What is the flow rating for stock 2j injectors.. Do they need to be replace if looking for like 400-500hp ? will a clean and flow test do the trick ? And who in brisbane does a cheap and good sonic clean..
    Default Re: 2jzgte injectors
    2JZGTE Japanese are 440cc.
    USA are 550cc.
    This info is easily found by Google and/or a search btw
    Wilbo's JZA80
    Wilbo's JZZ12
    You'll get about 360hp atw out of std injectors without upping fuel pressure. Have seen 550hp atw out of US 550cc injectors with 50psi idle fuel pressure(about 70psi on boost). This is pushing your luck though.
    Ive seen 300rwkw on 440's without bumping the rail pressure.
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    Sep 2009
    queensland
    what fuel pump should i be looking for ? When running T04 (ar.6 ar100) behind my 2j cressida. Im trying to buy all the bits i need before i come to see you Al.
    Need more details on turbo but a single Bosch 044 is good for around 380rwkw. What is the compressor inducer on the turbo?
    QUICKEST 1JZ'S IN OZ
    I make 350rwkw on stock vvti injectors, which I think are still 440?
    that is absolutely maxing them out though.
    Sep 2009
    queensland
    Sep 2009
    queensland
    i was looking through jzk25's thread on the 1j cressida and he mentions the bosch 909 is a better fitting one ? Does this flow more or less then a 044?
    http://boschfuelpumps.com/
    you'll want a bib for any more spoon feeding
    Quote Originally Posted by Draven View Post
    That is nuts! 466hp at the wheels. 440's should only flow 440hp at the engine basically. Well that is what I have always gone with with 6 cylinders. Stock FPR?
    Sard uprated unit
    pretty sure fuel pressure is stock tho
    Sep 2009
    queensland
    Love a good spoon feed thanks.
