Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: wiring injectors, efi relay, fuel pump vsv
    Default Re: wiring injectors, efi relay, fuel pump vsv
    Quote Originally Posted by wagonist View Post
    ST215 (Gen IV) onwards 3S-GTE is COP.
    My standard setup has a big resistor built into the injector circuit, do aftermarket ECU's need this too?
    Some do some don't need the resistor block for the injectors if you're running low resistance injectors, Motec don't, adaptronic don't unless you're running high duty cycles for sustained periods etc.
    You just need to see how the ecu controls the injectors and how well the injector drivers are heatsinked and keep an eye on the temps.
    My KE25 thread
    Brisbane
    fuck yeah, great diagram. i have it, but it's 100% in russian so i couldn't make sense of it.
    Brisbane
    Yep, that greatly helps me! Improved my understanding greatly... would be great if someone knows russian or whatever it is.............
    Because I also need the info I got some Russian guy at my brothers work just now to translate the bits that were still in Russian. Here is an update copy with the new translations in red. Some of it is probably not 100% but you can get the jist of it.
    Brisbane
    holy shit! that's awesome!!!
  1. 3RZ Hilux Turbo - Fuel Pump & Injectors
    By sash78 in forum Tech and Conversions
    Last Post: 23-09-2009, 05:37 PM
  2. Fuel pump wiring.
    By celupra in forum Tech and Conversions
    Last Post: 31-05-2008, 03:27 PM
  3. Replies: 20
    Last Post: 08-08-2007, 10:06 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
