more info man, got spark, injectors clicking? cranking over etc.
What wiring diagram did u use i really need one, cheers
heres the issue.
2jzge auto engine
2jzge auto loom
2jzge manual ecu (with neutral switch and reverse switch mod)
car wont start....why?? its like the immobiliser is armed, i can hear a relay click but thats all. got all the dash lights.
if you got nothing on tonight i would really appreciate the help. (brisbane)
op edited. its not doing anything at all
battery good?
earth from the engine to chassis good and clean?
all battery terminals can + and - clean to starter and body?
is the box actually in park/neutral?
will the motor turn over by hand with socket on crank pulley?
failing all those,
try bridging a wire from the solenoid strait to the batt this will at least tell you if its a fault with the starter..
