Results 1 to 5 of 5
Thread: turbo oil gasket
    Brisbane
    Default turbo oil gasket
    hey guys
    i've always made my own gaskets for oil pumps, etc using gasket paper from repco
    need a gasket for the oil feed & return to a turbo, are there likely to be any problems with the gasket paper in a higher temp environment like this? obviously the actual turbo flanges use metal gaskets, but this is just for the oil feed/return.
    vic
    Default Re: turbo oil gasket
    For the sake of $10 just get the genuine metal toyota one (guessing its a toyota turbo), make sure the feed/return is dead flat .
    Dave
    Brisbane
    nah it's for some nondescript nissan turbo... i'll see if i can get from a datto spares place
    gasket paper works for the return.
    im assuming you know to use the aviation non-hardening sealant on the gasket paper, to avoid any dramas.
    the feed is under pressure and is usually a banjo setup and should use a copper washer, you can get a pack of these for 2 bucks at your local auto store...
    Aug 2009
    +1 for buying the copper washers for the bango oil feed..... the oil return is under no pressure at all its gravity fed to the sump
    Last Post: 03-05-2009, 06:47 PM
  2. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 09:18 PM
  3. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
  4. Head gasket for 4agte
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-04-2006, 12:10 AM
