Results 1 to 6 of 6
Thread: st184 gt4 engine+driveline into st184, anyone done it?
    grease monkey Grease Monkey
    Default st184 gt4 engine+driveline into st184, anyone done it?
    hey all, just seeing if its possible to put the complete engine and 4wd system into a standard st184? my mate was seeing if its possible so PM or reply if you can help me out in anyway....
    Scott
    Studying to become a Domestic Engineer warrior's Avatar
    New South Wales
    Default Re: st184 gt4 engine+driveline into st184, anyone done it?
    Quote Originally Posted by Ta22boy View Post
    Scott
    the rear floor pan is totally different, you wont be able to bolt up the diff and subframe onto a ST184. the GT4 one is higher to allow for the diff and subframe.
    the St185 also has larger tail shaft well to allow for the tail shaft and exhaust.
    it would be cheaper just to buy a GT4.
    Karl
    always looking like a Grease Monkey fibrewizard's Avatar
    yes its possible......
    but why unless you got the cash and know-how..
    gt4's arent really that rare to get a hold of.....
    will cost $3500 for gt4 front cut to get everything you need for the conversion...
    then... you gotta cut the shit out of the rear chassis.... make mounting points for diff cradle, move fuel tank, re-inforce the rear chassis, make a new floor, rust proof, paint, and not something that can be done in a garage.... if measurement are slightly out on cradle mounts the diff will sit out of alignment and be a PITA to get wheel alligned.......
    yes.possible but why?
    edit.... plus the cradle, diff, axles, struts, brakes, for the rear end gonna set you back another $2000 minimum......
    so based on that its what $5500....... you can buy gt4's for that....
    2012 GT86
    V6 powered 5th gen celica. Sadly moved on to build below
    91 st185 aus delivered, V6 turb project,
    2015 Kun26r hilux
    a friend of mine is actually doing this atm.....
    V6 twin turbo AWD st184.....
    2012 GT86
    2015 Kun26r hilux
    yeah cheers guys, only reason for asking is i have a mate with a st184 that was wondering if it would go together. ill tell him to buy a GT4...
    Scott
    has no Toyota anymore :( Conversion King tooch's Avatar
    Yeah considering the scarily low price that GT4's go for now, I'd just buy one instead. At least it won't still be a POS fwd
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  4. MA70 --> JZA70 Conversion
