Results 1 to 4 of 4
Thread: low impedance 7mgte injectors work with high impedance HELP
    Jan 2009
    adelaide, SA
    Default low impedance 7mgte injectors work with high impedance HELP
    i need some help i tryed to search but can not find much. I have stock 3sge gen2 injectors "13.8 ohms", I want to upgrade my stock injectors to 7mgte injectors "3ohms" what do i need to do to get them running?
    im thinking put the injectors in, trace down the wires and wire in the supra resistor pack, but dont realy know how can any one give me some help.
    low impedance 7mgte injectors work with high impedance 3sge engine HELP
    Chiba
    Default Re: low impedance 7mgte injectors work with high impedance HELP
    With the resistor pack it should work. I would be installing the resistor pack from the same engine as the new injectors.
    Can't you find a set of high impedance injectors with the right flow though? Cost to effort ratio would probably work out better that way.
    Feb 2009
    Have a look at this,will be what i end up doing(hope it works)
    http://www.lextreme.com/R&D%20Injector.htm
    Jan 2009
    adelaide, SA
    Quote Originally Posted by TERRA Operative View Post
    yeah but i already have 7mtge injectors and resistor packs
  1. 7mgte injectors into 3tgteu - Pintle caps?
    By 3jcelica in forum Tech and Conversions
    Last Post: 17-01-2008, 08:34 AM
  2. injectors for teh p00 motor?
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 20-11-2005, 07:20 PM
