Results 1 to 2 of 2
Thread: Wastegate Selection Help
    Junior Member Backyard Mechanic DLA11D's Avatar
    Default Wastegate Selection Help
    Ok finally decided to something about my ebay external 60mm wastegate, and it doesn't want to play nice by sticking from time to time.
    My mate has a Tial 44mm wastgate he will give to for free, was wondering if it would be too small for my application??
    Currently running a T04z on my 2jz, currently making about 380+kw on 25psi and my low boost is set at 14psi.
    I have asked different places and keep getting a different answers, and also been told it will hinder power as the gases can't escape as quick.
    1992 Toyota Hilux Extracab
    2JZGTE - TO4Z powered.
    1968 Toyota Stout Lite
    Work in progress
    wa
    Default Re: Wastegate Selection Help
    If your low boost setting is 14psi a tial 44mm should be fine, if its free its worth a shot and will probably flow more than your 60mm ebay gate anyway.
    The wastegates job is to let excess boost escape so it will flow the most at a lower boost setting but i dont think a 44 will be too small.
    I am running pretty much the same setup as you and have a 48mm turbosmart gate and have been told by the tuner that it will be overkill unless i want to run under 10psi.
  1. Turbo Dump Design (Split wastegate vs Not)
    Last Post: 11-02-2009, 01:47 PM
  2. Killing Wastegate Creep
    By Z2TT in forum Tech and Conversions
    Last Post: 08-08-2008, 07:43 PM
  3. Wastegate size calculator
    By GriZZly in forum Tech and Conversions
    Last Post: 09-10-2007, 10:54 AM
  4. Swapping wastegate actuators...
    By mullett in forum Tech and Conversions
    Last Post: 28-07-2006, 10:21 AM
