Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: 4agze misfire
    Sep 2008
    Default Re: 4agze misfire
    Nah no worries, I don't think it is stupid at all....I agree with the whole one differs from the other...
    Just thought I would put my own personal experience out there lol
    The GOD HAND AW11 - sold
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    What condition is the fuel pump in? Leave that as your last checkpoint since it's the one that would be hardest to get to.
    I have been pruned by old man river!!!!!
    Aug 2009
    dont need to pull it out just do a fuel pressure test... youve got a fuel pressure reg so you should be able to have a look at the gauge on idle and give her a rev.. see if it drops off or goes back to a constant reading
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Check the sparks from each of the plug leads with engine running (idling) is easiest.
    I've had a stuffed DLI coil before on GZE - failing coils are usually worse under load.
    == 4AGZE SC14 Supercharged ==
    im a hardcore Backyard Mechanic LO01UX's Avatar
    Jun 2007
    I've done that were u pull the leads off n there all firing that's the problem
    BUILT NOT BOUGHT
    (\__/)
    Aug 2009
    did you gap the plugs?
    Jun 2007
    It ended up being the wire for the number 2 injector connector being loose causing it not to pulse thus the missfire,
    It took my boss all of 5min to figure it out
    BUILT NOT BOUGHT
    (\__/)
  8. #38
    Chiba
    Hah! Simple fix.
  1. 4agze build questions
    By ae86boy in forum Tech and Conversions
    Last Post: 06-11-2011, 03:59 AM
  2. 4AGZE Compression Advise needed
    By _FNQ_rolla_ in forum Tech and Conversions
    Last Post: 26-10-2008, 09:25 PM
  3. 4agze questions
    Last Post: 14-06-2006, 09:50 PM
