Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: MA61 F series IRS LSD + gears into YR22 F series?
    Drive Grease Monkey
    Feb 2009
    S.A
    Default Re: MA61 F series IRS LSD + gears into YR22 F series?
    So the mounts are on the F series, all i need now is an RT142 IRS tailshaft and some suitable handbrake cables...
    Had a look at some RA65 IRS F series drum handbrake cables today and they seen to have much smaller drums and are different where they connect into the back of the drum so dont think they are going to work. Hmmm.
    I might go back and grab the hbrake cables from the tarago i got the diff from and see if i can adapt them somehow but i dont like my chances. From memory the tarago cables ran in a weird way around the motor and they werent the same length as each other. Worth a shot i guess tho.
    RT142 Avant
    I've done some more research on the tarago diff and apparently they have a g series bolt pattern pinion flange. You will either have to get a flange off an ma61/rt142(irs)/ra65 or re-drill the flange you have on there now for the ma61/rt142(irs)/ra65 rear shaft to work.
    Drive Grease Monkey
    Feb 2009
    S.A
    Ah fuck! So it won't bolt straight in, trust the F diff i got to use a diff bolt pattern!
    I wonder how out it is, did you get any measurements? Re drilling seems like a fairly easy option.
    RT142 Avant
    Quote Originally Posted by wilbo666 View Post
    F Series Diff Flange: (RA65 Diff)
    55mm x 55mm Square [Checked]
    ~45.9mm Center bore clearance for spigot on tailshaft flange (~45.85mm OD for spigot on tailshaft flange) [Checked]
    G Series Diff Flange: (MZ12 Tailshaft)
    60mm x 60mm Square [Checked]
    Yes it is only for vans/commercials and mz12s for some reason they decided to put the g pattern flange on
    Drive Grease Monkey
    Feb 2009
    S.A
    Absolute champ.
    Same spigot OD, good.
    So at 2.5mm difference on each corner it should be easy enough to drill out the tailshaft holes to make it work and still hopefully have enough strength to take some abuse.
    Then to sort out the handbrake issue, got something in mind.
    Ill find a tailshaft and see how i go, cheers for all your help mate!
    RT142 Avant
  1. Guide: How to build a K series motor
    Last Post: 19-10-2007, 08:43 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
  3. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 08:53 AM
  4. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 07:51 PM
