Results 1 to 12 of 12
Thread: bigport cams in smallport 4agze
    im a hardcore Backyard Mechanic LO01UX's Avatar
    Jun 2007
    Default bigport cams in smallport 4agze
    Im guessing this has been asked many a times but I've searched and can't find anything...
    Can 4age 16v bigport cams be put into a 4agze 16v (which I have been told all have smallport cams)??
    If so is all I need to do is redo the valve clearances?
    Also what other cheap and easy to do mods can u do on a gze?
    BUILT NOT BOUGHT
    (\__/)
    Jul 2007
    Default Re: bigport cams in smallport 4agze
    yes u can swap them. best bang for buck would be a bigger crank pulley or smaller s/c pulley imo
    i agree, a pulley upgrade before you want to mess with the cams.
    Jun 2007
    Your sig is so tru feralmr2
    Yea I've got a smaller sc pulley from pulley bros coming I think its 103mm
    I've just got the standard 16v sitting at home n wana use some of the parts like cams n throttle boddy
    BUILT NOT BOUGHT
    (\__/)
    be sure it's a early 3 rib 4age bigport, otherwise it wont have the 7.56 cams.
    Apr 2008
    hey there
    i have the ae92 afm gze so do they have smallport cams not the bigport cam
    coz an't they ar bigport
    Jul 2007
    I beleive all gze's are supposed to have the 232deg 7.1mm lift "smallport" cams unless someone can prove otherwise
    Jun 2007
    The 4age I've got at home have tvis (which I thought was on all bigports) and is out of a 87 model ae82
    BUILT NOT BOUGHT
    (\__/)
    Quote Originally Posted by LO01UX View Post
    There are two bigport 4AGEs though, the 3-rib (originally had blue and black writing on the cam cover) and the 7-rib (red and black writing). It is only the 3-rib bigports that have the more aggressive cams, as well as smaller/lighter internals. Supposedly the last of the AE82s had the 7-rib, but quite a few have had engine changes by now so you can't always go by what was there stock.
    Chiba
    My AE101 GZE had smallport cams. I installed bigport cams with HKS cam gears, was a direct replacement.
    Just use a set of verniers to measure the cams to make sure they're the bigport cams.
    Jun 2007
    Ok kool, was there any noticeable difference?
    BUILT NOT BOUGHT
    (\__/)
    Chiba
    A little. Bit better midrange to top end, according to the bum dyno. Wasn't huge though (like a pulley).
    I've played with the cam timing a bit too, so it's a bit different from stock now (and develops more boost due to less overlap. 10PSI on stock pulleys)
  1. haltech 4agze idle stability (big cams).
    By nb86 in forum Tech and Conversions
    Last Post: 01-12-2005, 02:30 PM
