Sensor should be above horizontal
The issue of turbo is too much heat, not turbulence. If it is heated sensor, you can put it a lot further back.
Wide band are more sensitive to heat.
The issue with angle, is if it is lower than horizontal, condensation can run into it, it does not need to be vertical, just up enough so water cant pool inside it
(READ INSTRUCTIONS BEFORE WELDING PPLS) which can apparantly give the condensation issue, but i havnt had a drama in the 18 months it;s been on the car, including getting saturated when i did a HG, so dont think its super critical. im running mine about 50 cm back from the turbine outlet.
