Results 1 to 15 of 16
Thread: Haltech E6X Plug
    FWD 5H1T80X Racing Backyard Mechanic ROTFL-ACT's Avatar
    Default Haltech E6X Plug
    Does anyone what type of plug is that is used on the Haltech E6X??? What are they called??
    is it something specific to Haltechs or used for other things too?
    Race Car: Hyundai Lantra Super Touring Car
    Road Car - Ur Mums VX Commodore.
    perth
    Default Re: Haltech E6X Plug
    i THINK they are called deutsches connectors/plugs.
    Quote Originally Posted by fixeruperer View Post
    nah not Deustch. I've got Deutsch connectors, thought it may be too but i cant find it in the catalogue...
    Texas,USA
    I know they use GM pins.
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
    And whatever you use, make sure you keep the spacer piece in there - our FSAE car ran an E6X and was having terrible ignition/fueling problems (1 and 4 were running rich, 2 and 3 were running lean) and it was a bitch to start, on the way down to the '05 event our faculty supervisor (who was also our tow-er) took the car to Haltech, and the conversation went somewhere along the lines of this:
    *hands over computer for testing on benchmark
    "Ooh, that's a nifty thing you've got there, a little spacer to stop the pins shorting out on each other"
    "You mean this? That's standard on all our plugs, you should have got one when we gave you the loom"
    "Nope, never had it"
    One 10c piece of plastic later, and all our problems were solved.
    k so far i've found out its an AMP connector but having trouble tracking down the actual part no.
    Yeah, AMP connector. Unknown part number, its a custom made thing afaik. Even me going to an AMP supplier with the connector resulted in nothing.
    well at least i can get new pins. gotta redo the harness cos whoever done it before made huge cock ups cos almost every wire has at least 5 solder joints along the way. i plan to have zero
    now if Haltech would reply to my email confirming i will take the pins i will happily hand over the money... but they dont wanna reply so obviously they got enough money already
    I found Haltech were pretty average when it comes to emailing them, much better if you just ring them. They were pretty awesome when i did that.
    When i was having ECU issues (shorting out on the inside of the casing) they sent me a full ECU in swap until they could figure out the issue. Good service in my eyes.
    Just a pity that there arnt as many Haltech tuners down here. Is Pete still tuning up there, last time i was in Fyshwick i thought the workshop might have closed.
    Pete has moved to Hume...well his workshop has as he sold it to Ed and his offsider. Ed hates haltech
    theres not much to like about a Haltech is there? Thank fully i wont be using much other than ign/fuelling
    Ah poo, pity that Pete gave up the game. Ohwell.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Digging around google for the last hour I've found that Haltech used a "Packard 1211 0490"
    If you search that you only get back to haltech documents
    Packard connectors brings up Delphi Packard, a merger of two companies??
    So I looked up Delphi 36 way connector and it pointed me at Harley Davidsons.......
    http://www.hotbikeweb.com/tech/0805_...ing/index.html
    and
    http://www.bikernet.com/garage/PageV...sp?PageID=1301
    Seems that Delphi did some handy work on the twin cam HD efi gear, don't get excited, when they say twin cam I think they mean sohcx2.
    Looks the same to me, go look under the seat of a late model harley and tell me if it's the same plug or not, looks same to me
    Good luck!!
    Apologies for bringing Harley pictures tot he forum, I hope that it can be excused in this instance
    0402727834 Grease Monkey turbo ke20's Avatar
    haltech should be able to supply you a plug and the pins.
    I get all my bits and pieces through their wetherill park branch NSW
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    thanks c2888. further investigations from your links turns up its a Delphi Micro-Pack 100w 36F Connector
    Even found the crimper for it too which was harder then finding out what connector it was hehe
    Crimper #12125080 - also made by Delphi.
  1. MA61 5me to 5mge conversion guide
    By Enchanter in forum Engine & Driveline Conversions
    Last Post: 17-09-2013, 07:07 PM
  2. Mystery plug
    By Gary in forum Engine & Driveline Conversions
    Last Post: 17-01-2008, 10:31 PM
