ahh comprendeOriginally Posted by Norbie
not Necessary!Originally Posted by rob
when i fit the 1ggte and w58 to my ra40 there was no cutting/welding/grinding required at all![]()
i think because RA40's came with 20R's and w55's in the US (im guesssing here), the floorplan has 2 xmember positions, 1 for W50 and 1 for W55. i used the rearward position with my setup.
and then i simply turned the xmember around so it curved the other way, and reversed the gbox rubber mount.
and bingo, it all bolted up no problems![]()
because the RA28 doesnt have the 2 xmember position capability, some sort of modification will be required.
however i would sugest setting up the gbox rubber and xmember in a fashion that the holes are as close as possible.
you should be able to see this difference in mount postion between the W50 and the W55 if you stand both up on the output shaft end. the W55 mount will be lower compared to the poo-W50
these pictures were in the gallery on the old forums. its a 1ggte + w58 into RA28 conversion:
see more from this link http://www.toymods.org.au/gallery/th...s.php?album=38
ofcourse, you could have easily found them if you searched![]()
hello
ah yes.. i remember that gallery now.... and that car.
i was more concerned with the length of the box from input to output shaft. I didnt want to find that the tailshaft wouldnt fit...
i always thought that ra23 g/box x/members were the same as ra40 types as when i put the supra in all i did was swap the gear box mount around and it bolted to the xmember no probs ,and 2 this day thats all i used ,even the engine 1 i have is a ta23 for the engine as well ,and im almost sure that the extra bolt holes in the floor was for ta or ra motors and boxes any way ,just my 2 cents
ok, my 2 cents worth.
w58 1st gear- 3.28 w50 or p51 there are four variations
2nd -1.89
3rd -1.27
4th -1.00
5th -0.78
w58 there are 5 stick positions.
EG. from the centre of thegear stick (a the pin). 14 inch,18",19",20.5",21"
Obviously its an alloy box(supra oval case 5 speed)
front shaft 21 splines x 29mm [B]w50 -21 splines x 29mm[/B]
gearbox length- 22 inches [B]-22 inches[/B]
tail shaft splines- 21 -21
oil capacity 2.5 litres [B]-2.5 lts[/B]
weight 35 kg -40kg
thisbox can be distinguished by 9 bolts and 2 dowels holding the box to itsbellhousing.
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
just reading it agian karl it should just bolt in no probs no cutting no any thing
I used a TA63 gearbox xmember and it all bolted in![]()
The TA63 xmember has a lot more of a curve in it than the Ra28 one so it reached the original bolt holes fine.
... yeah, and im going to find one of those where??![]()
Originally Posted by The Witzl
i cant see why it would be any different to a SA63, or even a RA60/65. they all run a W55 as a manual with the exception of some RA65's (W58). i think also that the xmembers are the same between auto an manual but you'll have to sus that out for yourself....could be wrong.
hello
My TA63 crossmember is VERY similar to the crossmember from an auto TT132 so that may be an option.
Callum
TT132's are about as rare as TA63's though
hello
Not in NZ, sorry not really up with what you guys got over there. Was same as my RA63 crossmember too, but probably doesn't help either lol.
Callum
heehee... nah doesnt help, but thanks dude![]()
does if you want some postage ol witz@!
Black Betty >HERE!<
(\__/)
ha ha ha ah
I like that one.![]()
