Results 1 to 4 of 4
Thread: 1jzgte idle adjustment
    Default 1jzgte idle adjustment
    Hi all, my 1jzgte is idling very low.. in Neutral is it around 500rpm and in Drive around 400rpm.
    The idle motor seems to be working as when its cold it idles around 1300rpm.. But just drops too much it seems when its warm.
    So is there a way to adjust?
    Thanks
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default Re: 1jzgte idle adjustment
    mine is also idling pretty low when warm 500-600ish (manual), iscv is working properly.. although my car needs a tune pretty badly
    i guess you could wind the screw in/out that stops the TB closing?
    87' z20 Soarer - 1jz Gt35r -
    Remove and Clean the ISCV . They play up and this s a common issue. Or even try an ECU reset 1st , or do both
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    Jul 2009
    all else fails adjust the bypass valve on the tb
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
  1. RA28 1jzgte Very Strange Idle and Running issues
    By 77GZE in forum Tech and Conversions
    Last Post: 19-02-2008, 06:44 PM
  2. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  3. 1JZGTE problem, rev limiter/ idle
    By GZP51 in forum Tech and Conversions
    Last Post: 24-09-2006, 04:38 PM
