Results 16 to 17 of 17
Thread: How to fit/remove one piece FWD driveshafts?
    Jul 2009
    Default Re: How to fit/remove one piece FWD driveshafts?
    Quote Originally Posted by wagonist View Post
    Anyway, if you have trouble getting the shafts out of the gearbox (like I did recently), here's a little trick that most people will tell you not to do
    I had the lower ball joint & the tie rod ends removed.
    grab the hub & pull it out until it will come no further (puts the inner CV on its full extension)
    give a short sharp tug directly outwards
    shaft that had stumped me for about 4 hours popped straight out, and with a lot less force than I expected.
    The passenger side
    this is the way most workshops remove them ... good to see some sound advice
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    If you do it that way with a tripod inner CV joint, and the strap is less than tight, you'll probably end up with the shaft in your hand, the spline still in the gearbox, and sloppy old grease running out onto the floor. The ones with retainers to stop them coming out, go for it.
    I do this at least once a week. 2 nuts/1 bolt on the LCA is the easiest way. Then either a lever bar to get it out of the gearbox, or if that fails, a brass drift and a hammer.
    Be sure not to damage your driveshaft seals putting them back in.
  1. AE101 4AGZE superstrut driveshafts
    By L4AGZE in forum Tech and Conversions
    Last Post: 11-11-2008, 12:47 AM
  2. 2 piece tailshaft - length issues...
    By shelldrake in forum Tech and Conversions
    Last Post: 19-10-2008, 02:33 PM
  3. Toyota FWD driveshafts differences (inculding MR2s)
    By wagonist in forum Tech and Conversions
    Last Post: 30-01-2006, 10:56 PM
