Results 1 to 6 of 6
Thread: 4agze ignition timing
    im a hardcore Backyard Mechanic LO01UX's Avatar
    Jun 2007
    Default 4agze ignition timing
    ok so i finally got my gze running but now i have realised that stupidly i dont think i put the distributor back in on TDC
    does anyone know where it should be sitting at tDC as it would really help!!
    thanx
    BUILT NOT BOUGHT
    (\__/)
    Jul 2007
    Default Re: 4agze ignition timing
    there should be like a dimple on the shaft which then lines up with another mark on the housing.
    searching for pics now
    Jul 2007
    http://media.photobucket.com/image/4...2/IMG_1420.jpg
    line up the actual dimples, not the press pin or whatever it is
    Jun 2007
    Ok kool so I line then up and have the engine on TDC n then slot it in and it should be all good?
    BUILT NOT BOUGHT
    (\__/)
    Jul 2007
    afaik you need to line up the timing mark on thew crank to tdc, the dimples on the cams to tdc, and the dizzy. The cam appreaing under the oilcap should also have a notch facing upwards. I think that's all that there is to it. Cuzzo explained it to me when we were setting the timing on my 4A-GZE, but I may have forgotten something along the way.
    There should be guides online for confirmation
    Chiba
    The "pointy" bit on the rotor in the CAS should be pointing almost straight down IIRC too.
  1. 20v ignition timing
    By d.s in forum Tech and Conversions
    Last Post: 17-12-2008, 02:46 PM
  2. 4AGE red top ECU ignition timing
    By CHB in forum Tech and Conversions
    Last Post: 09-12-2008, 07:33 PM
  3. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
  4. timing curve(s) for 18RTE
    Last Post: 20-04-2006, 01:50 PM
  5. Oil leak 4agze DLI type ignition
    By clean82 in forum Tech and Conversions
    Last Post: 30-03-2006, 10:46 PM
